Author Topic: spark plugs  (Read 10330 times)
Offline mikewb
Re: spark plugs
« Reply #15 on: January 09, 2008, 03:50:52 pm »
wd 40 wont eat up anything will it?
Offline mikewb
Re: spark plugs
« Reply #16 on: January 09, 2008, 07:04:34 pm »
also it has hard time starting when cold and runs real rough at first
Re: spark plugs
« Reply #17 on: January 09, 2008, 08:07:03 pm »
Did you check for vacuum leaks? Cup your hand over the top of the carb as to restrict the air flow and see what happens.... Don't block it off totally (good way to break a ring)
Offline mikewb
Re: spark plugs
« Reply #18 on: January 10, 2008, 05:09:01 pm »
I covered it as much as possible and still didnt die. should i be able to squeese the vaccum line for the transmission?
Offline Fordeatinz71
  • 78k miles and counting
Re: spark plugs
« Reply #19 on: January 10, 2008, 09:07:14 pm »
man, the SAME thing happened with my '88 Mustang GT.  i was baffled as to why the idle was really high/erratic and it ran like crap...i had tried most everything, couldn't find a vac. leak...one day i was screwin around and decided to cover the TB to kill it...it sucked in the cardboard (just grabbed a piece to cover the TB) tight to it and KEPT RUNNING!  i cracked up.  then i went and got intake gaskets and all was well after that...
Offline mikewb
Re: spark plugs
« Reply #20 on: January 11, 2008, 03:21:06 pm »
hmm. i covered it with both my hands as much as i could it started to stumble but didnt die. but i cant find any leaks around the intake.
Re: spark plugs
« Reply #21 on: January 11, 2008, 10:36:39 pm »
well, if you covered the carb and it still had enough air to keep running, where do you think it's getting it from?  lol, there IS a leak, and a pretty good one if it's enough to keep it running.  it is most likely at the end of the intake where you can't really spray...you need intake gaskets...
Re: spark plugs
« Reply #22 on: January 12, 2008, 10:00:04 am »
Mist down your wires/distributor cap with some water and see if it runs worse.
