Engine/Drivetrain
EGR Valve replacement
Topic: EGR Valve replacement (Read 3871 times)
scubasteve65
January 20, 2008, 09:37:52 pm »
'78 1500 250 6cyl 3spd. Anyone know how EGR is attatched? Some are flanged with bolts. This one is not. I don't even know where to put a wrench on it.
TexasRed
Re: EGR Valve replacement
January 21, 2008, 12:01:42 am »
Yikes, Looks like maybe on the backside?
http://www.partsamerica.com/ProductDetail.aspx?MfrCode=GPS&MfrPartNumber=7792272&PartType=282&PTSet=A
scubasteve65
January 21, 2008, 04:34:44 pm »
thanks for the link. At least from that picture I can see there is some place to put a flat wrench on it while I loosen it from the other.
January 21, 2008, 07:35:53 pm »
Did you remove the carburetor?
scubasteve65
January 22, 2008, 06:05:41 am »
Not yet. Going to have a better look when the sun comes up.
scubasteve65
January 22, 2008, 08:45:27 am »
I took a closer look and got it. You can sort of see it in one of the above pics. It's a flat 2 tine fork that has a single bolt to the manifold and it reaches across and presses on the top and bottom side (which I could not see). Stupid set up.
Engine/Drivetrain
