Author Topic: EGR Valve replacement  (Read 3769 times)
Offline scubasteve65
« on: January 20, 2008, 09:37:52 pm »
'78 1500 250 6cyl 3spd. Anyone know how EGR is attatched? Some are flanged with bolts. This one is not. I don't even know where to put a wrench on it.
Offline TexasRed
Re: EGR Valve replacement
« Reply #1 on: January 21, 2008, 12:01:42 am »
« Reply #2 on: January 21, 2008, 04:34:44 pm »
thanks for the link. At least from that picture I can see there is some place to put a flat wrench on it while I loosen it from the other.
« Reply #3 on: January 21, 2008, 07:35:53 pm »
Did you remove the carburetor?
« Reply #4 on: January 22, 2008, 06:05:41 am »
Not yet. Going to have a better look when the sun comes up.
« Reply #5 on: January 22, 2008, 08:45:27 am »
I took a closer look and got it. You can sort of see it in one of the above pics.  It's a flat 2 tine fork that has a single bolt to the manifold and it reaches across and presses on the top and bottom side (which I could not see). Stupid set up.
