Author Topic: Brake Issues  (Read 4064 times)
Offline 76_Scottsdale
  • I'd rather push my Chevy than drive a Ford
Brake Issues
« on: January 23, 2008, 05:46:01 pm »
Well the cold weather is back. Here in Ellensburg it's been in the single digits for the last 3 days and I've noticed a problem with my brakes. Sometimes when I am stopped and holding the brake pedal it will slowly go to the floor and the brakes will let go. It doesn't do it very often, but enough to worry me about running into a parked car or something. The fluid level is fine but looks a little dark, and I've checked the calipers and drums for leaks and found nothing. So, what could be the problem? I don't think the booster is losing vacuum, I've checked the connection. Maybe a master cylinder? I want to add disc brakes in the spring so if I could hold off on a master cylinder until then it would be great. By the way it's a '76 K20 thanks again.
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
True Dual 3" Flowmaster 40 Series Exhaust
Offline jonkmbll89
Re: Brake Issues
« Reply #1 on: January 23, 2008, 06:09:34 pm »
It sounds like your master cylinder. If the power booster went out your brakes would be hard.
Re: Brake Issues
« Reply #2 on: January 23, 2008, 06:36:05 pm »
Yep, If you have no external leaks replace the Master Cylinder
Re: Brake Issues
« Reply #3 on: January 23, 2008, 10:05:48 pm »
Right on I love it when I get answers so quick thanks guys. I'll just get a cheapo one from Autozone for now because i'm going to use a disc/disc one in the spring. Thanks again.
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
