Author Topic: leaky 250  (Read 4107 times)
Offline the_legend_1981
leaky 250
« on: February 01, 2008, 01:13:01 pm »
what are the common oil leaks in the 250 straight 6?  it's toward the front...drips after i shut it off
Re: leaky 250
« Reply #1 on: February 01, 2008, 04:13:57 pm »
You'll have to be more specific. Oil, Coolant? Basically every component with a seal, gasket or hse etc is a potential leak.
Re: leaky 250
« Reply #2 on: February 01, 2008, 04:45:09 pm »
oil...i was just wondering if there were any common place in these engines that this occurs
Re: leaky 250
« Reply #3 on: February 01, 2008, 04:47:11 pm »
Yes, basically everything! Valve cover gasket, front cover, crank seal, oil pan, rear main seal are the most common leaks.
Re: leaky 250
« Reply #4 on: February 01, 2008, 05:25:04 pm »
ok thanks
Re: leaky 250
« Reply #5 on: February 04, 2008, 02:51:51 pm »
it looks like it's coming from the front around the distributor
