General Discussion
I have some questions.....
Topic: I have some questions..... (Read 7948 times)
FlatBroke
February 05, 2008, 09:31:27 pm »
About sound deadening materials.
I have an 81 GMC and don't want a lot of wind and road noise when I drive it down the interstate to work once I get it on the road. I did a little research and found a few informative articles on sound deadening. Can't really spend a lot of money (mainly cause I'm a cheapskate) on this little portion of the project. One of the articles I found said that "Peel-n-Seal" was a lesser expensive alternative than Dynamat and found some at Lowes very reasonably priced. Main questioons are...
"Will it get the job done",
"How bad is the smell in the sumer",
"can I put on multiple layers"
Im always open to suggestions as well.
Thanks for your input.
It's not the tires screaming, It's the asphalt
http://forum.73-87chevytrucks.com/smforum/index.php?topic=7217.0
Re: I have some questions.....
February 05, 2008, 09:37:32 pm »
1st I would make sure you have no air leaks around your vent windows or all you're going to hear is noise. Whistling and such. I've used home carpet padding and had good luck with it. Never used peel n seal so I can't offer you any suggestions there.
choptop
Extended cab fanatic
February 05, 2008, 09:43:16 pm »
carpet paddong works real well, but I have used roofing tar paper as well and it does good as well,especially in layers,
the_legend_1981
February 06, 2008, 10:42:58 am »
where do you guys put the carpet padding? The truck my brother just bought has a second gasket running along the top half of the door...i've never seen this...maybe you guys have
ccz145a
February 06, 2008, 11:18:30 am »
My '75 had this gasket. The catalog
http://www. competitor.com/icatalog/cc/full.asp?page=17
says it is a '79-'81 feature, but I know my '75's door was stock.
the_legend_1981
February 06, 2008, 11:49:57 am »
yeah that's it...his is a 77...these seem to work pretty good
FlatBroke
February 06, 2008, 08:16:39 pm »
I do plan to replace all gaskets and such around the doors and vent windows.
Had not thought of carpet padding but may try it. Someone on another forum suggested the "Herculiner", can anyone offer any experience with that.? Good, bad, or indifferent.?
Thanks for all the help guys...Please keep it coming.
zieg85
February 06, 2008, 08:40:23 pm »
The roofing valley roll is thick and has one side that is sticky. Easy to cut and definately works.
My $.02
monte85
February 06, 2008, 10:14:55 pm »
herculiner is rather expensive (i think it was about $30 per can when i did my inner fenders). i think you would use alot and maybe have to layer it to get the quiet you want. it doesn't go on very thick. i put on 2 layers and used about 3 of the quart sized cans on both in and out of my inner fenders.
"Of my friend, I can only say this: of all the souls I have encountered in my travels, his was the most... human."
FlatBroke
February 07, 2008, 09:53:18 pm »
I was actually looking at something such as the roofing vally roll or some sort of thick flashing at Lowes the other night ant the guy said it might be overkill....I just kinda had to grinn and said thanks...
But that is basicly the answer I was looking for.
werewolfx13
Site Supporters
February 08, 2008, 09:32:41 pm »
In my experience from smelling cars that used peel n seal (roofing valley roll), when it gets hot, you can smell it..IMO, if it can be smelled at all, its too strong. I would suggest you buy a gallon of edead v3 online somwhere, and use carpet padding over that..Herculiner is not thick enough to adequately reduce noise with less than 5-10 good heavy coats, which would add up to be about 3-4 gallons @ $75 a gallon...Edead v3 was like $40 a gallon the last time I bought some on ebay. Shipping was $20 though..
Chris
'83 Chevy c10 Silverado SWB
FlatBroke
February 09, 2008, 10:00:58 am »
OK,
Thanks WW13.
I'm taking all this info in to consideration.
General Discussion
