Author Topic: SEATS and brackets????  (Read 9873 times)
Offline 79SHORTWIDE
    • 79 SHORTWIDE
« on: February 09, 2008, 10:16:53 am »
Curious to know what everyone is using for seats and mounting brackets (other than stock bench seats). I'm wanting to put buckets and some sort of smaller/fold up style center seat. I'm planning to run a B&M Pro Stick shifter and will likely build some sort of center console so the shifter isn't a mile away when I need to shift. Hate to reach way down and I think it'll look crappy.
If anyone has any pics of their setup, please post them.
Thanks !
Offline 79diesel
Re: SEATS and brackets????
« Reply #1 on: February 09, 2008, 04:31:20 pm »
94 mustang buckets...i made a set of custom brackets and just mounted the seats in a permanent position
Offline 79SHORTWIDE
    • 79 SHORTWIDE
« Reply #2 on: February 09, 2008, 11:13:01 pm »
They look good !
I'd probably have to make sliding brackets for the stereo equipment I plan to install.
Thanx for your input !!!!
« Reply #3 on: February 10, 2008, 09:03:11 am »
In my opinion nothing fits better than a replacement aftermarket seat if you want a matching center although I am going to fabricate a set of Saturn seats that I have that are brand new into my next project to see how they look. I will post pix when I do it. Here's the one I put in my 85
Offline 79SHORTWIDE
    • 79 SHORTWIDE
« Reply #4 on: February 10, 2008, 09:21:58 am »
Funny you mention SATURN....I'm a parts manager for the one here in Austin, Tx. (off the subject a little)- I used some of the exhaust that was prebent from the Sky Turbo to make my system since I don't have a pipe bender. I used two systems (customers that upgrade to the performance exhaust and intake package leave their o.e. exhaust behind--it would normally be scrapped. So, I cut the pipe and made it work. Anything to help save $$$$. You may have seen it elsewhere on this site.
Back to the topic- which seats are you going to use? Do you know what they're from (which Saturn)?
I like what you have in your truck. They look good. My plan is to probably build a center console to mount the shifter to so it's easy to reach as well as possibly mount stereo equipment and an e-brake handle.
Offline hogwild
« Reply #5 on: February 10, 2008, 09:49:11 am »
anyone try seats out of a newer  model chev-gmc truck, i have a 05 gmc with buckets& console, i have thaught they would look nice in my truck, but never checked to see if they wouldd fit or not
1986 sb 406 ci
2003 mud buggy 1300 hp 528
if my wife askes it was only fifteen bucks
Offline okuma
« Reply #6 on: February 10, 2008, 10:28:54 am »
There is a local upholstery shop that has a set of 2000 something seats. he said they would fit with some mode but would fit.
Offline 79SHORTWIDE
    • 79 SHORTWIDE
« Reply #7 on: February 10, 2008, 10:29:33 am »
I've seen alot of the newer style like you have but finding them is next to impossible unless you want to drop some serious coin.
« Reply #8 on: February 10, 2008, 12:05:11 pm »
The Saturn I have is a 2000 L series. It was a cutaway showroom car that i got but at this point the car has outlived it's usefullness so I'm gutting it.
Offline chevyguy5894
« Reply #9 on: February 10, 2008, 03:35:47 pm »
Heres the 99-02 seats I put in my 76.
Had to mount them stationary. I think the 03 and up seats are about a inch smaller.
To make the sliders work you would have to hack your floor unless you have a blazer or burb because they have flat floors.
« Reply #10 on: February 10, 2008, 05:06:21 pm »
I never took pictures, but I put a set of mid 80s Dodge Caravan seats in a buddy of mines truck. Made brackets and mounted a Blazer center console in the center.
Offline 123 pugsy
« Reply #11 on: February 10, 2008, 05:16:13 pm »
Leather buckets from a Jeep Cherokee and jump seat from an F100 I believe.
I made custom brackets and they're bolted in with the original bolt holes. ( 2 per seat only) :o
Pugsy
76 C10 LWB
TPI 350
Offline JRConnieK10
« Reply #12 on: February 10, 2008, 05:48:55 pm »
I've got a set from an 02' dually power and all with center console for $200 I got them sittin' in the garage and keep looking at them to see how I can get them in I thought about trying to change the floor section to that of a blazer but I don't want to chop it up cause I would have to move the fuel tank also to much trouble I also like them because they have the seatbelts built in I'll get some pics when I start to tear into them.
'85 K10 LWB 350/SM465
BUILT NOT BOUGHT
