Author Topic: cab  (Read 24777 times)
Re: cab
« Reply #15 on: February 22, 2008, 12:20:57 pm »
Doesn't matter on the molding.  You could get it out of an 87 and it will fit.
Offline hotrod24
Re: cab
« Reply #16 on: February 22, 2008, 01:57:35 pm »
ok that is good because i found molding off of a 85
1978 pontiac grand prix...
Offline hotrod24
Re: cab
« Reply #17 on: May 02, 2008, 06:30:37 pm »
i was looking at my cab and i seen a dent on the outside and in the inside there you could see it to what should i do about this i tryed to fix it with a hammer but did not work out my best guess is to take a spot welder and do it that way
« Last Edit: May 02, 2008, 09:13:04 pm by hotrod24 »
Re: cab
« Reply #18 on: May 03, 2008, 04:22:26 am »
Its behind the seat, & inbetween the bed and cab, why do you care, if it were me I would leave it dented?
Offline ccz145a
Re: cab
« Reply #19 on: May 03, 2008, 07:03:47 am »
Ditto what blazin said, you got enough other major things to worry about. Get back to it after the rest of the truck is almost perfect. The only way you are going to finish is to stay focused.
Offline hotrod24
Re: cab
« Reply #20 on: May 03, 2008, 11:29:28 am »
 i wanted to put some nice speackers back there and make it look nice and it is one of those things that just bothers you
« Last Edit: May 03, 2008, 12:13:51 pm by hotrod24 »
Offline hotrod24
Re: cab
« Reply #21 on: July 08, 2008, 09:47:15 pm »
ok i was working on these holes and waiting to get a welder and weld them up but i dont know if i should put filler in them or weld them which one would be the best
Offline Fordeatinz71
  • 78k miles and counting
Re: cab
« Reply #22 on: July 08, 2008, 09:54:07 pm »
i'd weld them myself, but then again, i don't like body filler.  body filler would hold up well in a place like that and i don't think anyone would ever know but you.  i have those same holes in mine, but only 4...i had a gun rack too...i still have it actually, i took it out...its behind my seat, lol
Offline hotrod24
Re: cab
« Reply #23 on: July 08, 2008, 10:01:38 pm »
yea i have 4 that is from a gun rack and the others i dont know where they come from but if i did weld them how would i do it with a mig welder
« Last Edit: July 08, 2008, 10:06:38 pm by hotrod24 »
Offline 80stepsideguy
Re: cab
« Reply #24 on: July 09, 2008, 01:29:11 pm »
Start off slowly by building up around the hole, go slowly cause you dont want it to fall out and melt the metal then your really screwed, build up the metal, grind it down and if you see small little pin holes, tack it snd grind again till theres really nothing left but a smooth surface, but after your done i reccomend using USC all metal to smooth the work , it wont crack, shrink or peel if applied correctly.
thanks
pat
1998 Chevy 1500 S/B 2wd
Offline hotrod24
Re: cab
« Reply #25 on: July 09, 2008, 01:48:28 pm »
ok thank you
Offline hotrod24
cab
« Reply #26 on: July 09, 2008, 03:20:17 pm »
ok got it thanks for the help
« Last Edit: July 10, 2008, 11:47:59 am by hotrod24 »
Offline Bitzer!
  • Smiles per gallon
Re: cab
« Reply #27 on: July 13, 2008, 06:15:34 am »
Find a small bolt thats just bigger than the hole. Tap it down so the head is just below the panel then weld in. All u need then is a quick skim and hey presto. It also helps to stop any filler from sinking as you've now got a solid base to work from.
My trucks got all sorts welded in to bridge small gaps etc and it saves cutting out good metal to get to it.
1979 GMC CrewCab  C20 1t
Offline ccz145a
Re: cab
« Reply #28 on: July 14, 2008, 08:31:18 am »
Bitzer, nice trick. Thanks.
Offline Bitzer!
  • Smiles per gallon
Re: cab
« Reply #29 on: July 14, 2008, 12:23:05 pm »
and for really tight places thread a nut onto a bolt that fits the hole. spot weld the nut to the body then unscrew bolt and nut stays there   ;)
