Author Topic: cab  (Read 24775 times)
Offline hotrod24
cab
« on: February 11, 2008, 02:19:25 pm »
i have some holes where some one put a gun rack up and  i want to know how to fix them they stick out a little bit so i guess i would have to grind them with something maybe a dremel but i do not know
« Last Edit: July 10, 2008, 11:54:31 am by hotrod24 »
1978 pontiac grand prix...
Offline werewolfx13
Re: cab
« Reply #1 on: February 11, 2008, 02:55:50 pm »
...Why not just put another gun rack in it...every 4x4 chevy needs a gun rack..  ;D
Chris
'83 Chevy c10 Silverado SWB
Offline monte85
Re: cab
« Reply #2 on: February 11, 2008, 10:52:31 pm »
take the round end of a ball-peen hammer and use it to tap the high spots down. then you can use alittle body filler or even weld the holes closed. sand or grind smooth, paint and your done.
"Of my friend, I can only say this: of all the souls I have encountered in my travels, his was the most... human."
Offline hotrod24
Re: cab
« Reply #3 on: February 11, 2008, 11:13:07 pm »
think you i will try that
Offline monte85
Re: cab
« Reply #4 on: February 11, 2008, 11:21:40 pm »
someone put one of those cab visor things on my cab. that's what i did to fix the holes. tap them below the surface a bit, almost like a tiny dent. it will be easier to hide them which ever way you decide to fill the holes.
Offline hotrod24
Re: cab
« Reply #5 on: February 14, 2008, 04:04:28 pm »
hey i found a leak on my rear sliding glass window i might switch to original but i do not know
Offline hotrod24
Re: cab
« Reply #6 on: February 20, 2008, 05:01:02 pm »
well i done a little grinding to day on my cab i thank it might turn out good
« Last Edit: February 20, 2008, 07:01:42 pm by hotrod24 »
Offline hotrod24
Re: cab
« Reply #7 on: February 20, 2008, 06:59:51 pm »
does anybody have any pics of this area of there head liner it is the back window and i was wonder how a head liner look like with out the factory molding some trucks came out with know head liner and mine does not have one so i wanted to see a head liner like that
« Last Edit: February 20, 2008, 08:35:38 pm by hotrod24 »
Offline HAULIN IT
Re: cab
« Reply #8 on: February 20, 2008, 09:00:15 pm »
Hotrod, The headliner angles down to just above the rear window, I don't think it would look real good just left without the moldings. Maybe you could search a salvage yard for the trim parts? They seem to stay in fairly good shape after many years. You would also have to come up with some way of holding the headliner up due to the original was held up by the trim. Lorne
Offline hotrod24
Re: cab
« Reply #9 on: February 20, 2008, 09:14:47 pm »
Re: cab
« Reply #10 on: February 20, 2008, 09:39:34 pm »
We have the same EXACT thing for sale, but it is only $154.95 + shipping and it comes with sail panels.
Offline hotrod24
Re: cab
« Reply #11 on: February 20, 2008, 09:54:01 pm »
well i do not know if it would look good with a head liner with molding or with out the molding as haulin it said it would not look very good with out the molding
« Last Edit: February 20, 2008, 10:57:18 pm by hotrod24 »
Offline hotrod24
Re: cab
« Reply #12 on: February 21, 2008, 04:55:23 pm »
i think a have made up my mine i am going with the molding it would look better i just do not know what year to get because of my truck having different parts the molding i mean
« Last Edit: February 21, 2008, 05:38:35 pm by hotrod24 »
Offline ccz145a
Re: cab
« Reply #13 on: February 21, 2008, 05:46:45 pm »
Think the moulding was all the same. If not, it will all fit well anyway. I have 2 complete black sets, one from a 75 and another from an 84, both the same. Check back with me in a couple of months after I put 1 set in, I should have another set left over. Just can't get rid of either yet.
Offline hotrod24
Re: cab
« Reply #14 on: February 21, 2008, 07:16:47 pm »
ok that would be good i thank my cab is a 74 so that 75 molding would probably work
