Author Topic: cab  (Read 24776 times)
Offline hotrod24
Re: cab
« Reply #30 on: July 14, 2008, 12:30:59 pm »
would it be smooth where you could see it?
1978 pontiac grand prix...
Offline Bitzer!
  • Smiles per gallon
Re: cab
« Reply #31 on: July 14, 2008, 12:47:34 pm »
If the hole is to big for the weld to bridge with the mig welder, dimple the hole with a ball hammer then drop bolt in     --------          ---------
and weld where the dashes meet the stars at the top. Dont go mad in one go and keep cooling the metal or it'll distort. If any well is proud of the hole grind off flush with panel then skim and sand. hey presto
1979 GMC CrewCab  C20 1t
Offline hotrod24
Re: cab
« Reply #32 on: July 14, 2008, 12:57:10 pm »
ok so you grind the bolt so it will be flush with the cab?
Offline Bitzer!
  • Smiles per gallon
Re: cab
« Reply #33 on: July 14, 2008, 02:12:37 pm »
if you tap the hole inwards 1st then drop the bolt in, the head should be below the panel line. then weld it in and grind any weld flush.
Offline Bitzer!
  • Smiles per gallon
Re: cab
« Reply #34 on: July 14, 2008, 02:22:23 pm »
Hope the picky helps. its not the best but hope u get the idea  ;)
Offline hotrod24
Re: cab
« Reply #35 on: July 14, 2008, 02:49:18 pm »
ok i get it now i need to get a ball point hammer because the holes are bowed out
Offline Bitzer!
  • Smiles per gallon
Re: cab
« Reply #36 on: July 14, 2008, 04:33:45 pm »
Stiff upper lip " By Jove I think he's got it"
 ;D
« Last Edit: July 14, 2008, 04:40:15 pm by Bitzer! »
Offline hotrod24
Re: cab
« Reply #37 on: July 14, 2008, 06:37:18 pm »
thank you
Offline Bitzer!
  • Smiles per gallon
Re: cab
« Reply #38 on: July 25, 2008, 10:58:19 am »
Any pic's Hotrod? Howz it goin?
Offline hotrod24
Re: cab
« Reply #39 on: July 25, 2008, 01:00:03 pm »
well i thought i was going to get a welder but i did not get it but when i do i will start thank you for your help
Offline Bitzer!
  • Smiles per gallon
Re: cab
« Reply #40 on: July 25, 2008, 03:30:30 pm »
Make sure you keep me updated i'm well interested how u get on  ;)
