Author Topic: seam sealer  (Read 8340 times)
Offline plowking_90
seam sealer
« on: February 11, 2008, 02:22:26 pm »
where can i find a factory grade seam sealer like the use in the cabs and beds of our trucks?
Offline HAULIN IT
Re: seam sealer
« Reply #1 on: February 11, 2008, 02:30:42 pm »
Plowking, Any good autobody supply store should have some. The best I have found is a two part type made by Kent, which I believe is sold only through a distributor. It is rather expensive (about $35 a tube). Maybe you could check with a local bodyshop & see if they have access to it. There are other, more readily available sealers from Fusor & 3M also. Lorne
Offline plowking_90
Re: seam sealer
« Reply #2 on: February 11, 2008, 02:43:12 pm »
do you think a store like napa or advance auto will carry something like this?
Offline flthead
Re: seam sealer
« Reply #3 on: February 11, 2008, 04:15:51 pm »
been doing body work for ever , i use this 3m sealer     http://solutions.3m.com/wps/portal/3M/en_US/3MAutomotive/Aftermarket/Products/Product-Catalog/?PC_7_RJH9U5230GE3E02LECFTDQCEK3_nid=GSC5NRW78Tbe6DTWTJQPBBgl     i use a little prep solvent with a acid brush to flow it out
37 p.u. 44 g506 military .54 panel  65 p.u. 70 p.u.  82. p. u.
Re: seam sealer
« Reply #4 on: February 11, 2008, 05:05:55 pm »
That's how I do it too flthead. Works mint. Any decent autoparts store will have the 3m
Offline the_legend_1981
Re: seam sealer
« Reply #5 on: February 11, 2008, 07:21:27 pm »
how much does the 3m go for?
« Last Edit: February 11, 2008, 07:23:37 pm by the_legend_1981 »
Re: seam sealer
« Reply #6 on: February 11, 2008, 08:21:01 pm »
just google search the kind you want http://www.levineautoparts.com/3mulause.html
Offline Dragon
Re: seam sealer
« Reply #7 on: February 12, 2008, 10:44:39 pm »
GM has been using 3M Sealers since the 1970's when our trucks were new... You can even go down to your Local Stealership Parts Dept for some, Pay 2-3times the price the Parts/Autobody Supply Stores want, and just get a GM Labeled Box & Tube, with 3M in the fine print ;D
Dragon
08 Magnum-New Toy
96 Caprice 9C1-Who Knows
96 GMC ECLWB & 92 Chevy ECLWB
