Author Topic: Fuel Pressure Gauge  (Read 78901 times)
Offline JJSZABO
Fuel Pressure Gauge
« on: February 14, 2008, 09:24:52 am »
Has anyone added a permanent fuel pressure gauge to their 4bbl Q-jet?  If so, how did you do it?  Pictures?
I want to do it and do not want to reinvent the wheel.  Thanks.
Jeff
86 Chevy C-10
350, TH400
Re: Fuel Pressure Gauge
« Reply #1 on: February 14, 2008, 10:23:54 am »
Sure, just put it on your fuel pressure regulator assuming you have one? Otherwise knowing your fuel pressure is kind of pointless. Fuel volume is more important than fuel pressure with a carburetor so unless you are running a high performance pump be it mechanical or electric you shouldn't need a regulator or gauge unless you are trouble shooting a problem.
Offline JJSZABO
« Reply #2 on: February 14, 2008, 02:26:08 pm »
I only ask cause I am suspect in how I installed my mechanical fuel pump.  I will soon try to start this thing and I thought that if I installed a fuel pressure gauge it would tell me right off if the fuel pump is working properly - maybe I am thinking too much ::)
What you said makes sense though Vile - thanks.
Jeff
86 Chevy C-10
350, TH400
Offline HAULIN IT
« Reply #3 on: February 14, 2008, 02:47:50 pm »
Jeff, I made a "test" fitting for a q-jet using an extra Big nut,where the filter goes (long style,Pont,Olds) a flat washer (to cap off the big end) & an extra fuel line nut w/a short piece of in it, all neatly brazed together. I drilled a hole & brazed a 1/8" pipe coupler on the side of the big nut for the gauge or line to the gauge. This way you can remove the stock line, install "the rig", test & put back when your done. This way is a little safer than some rubber hose set-up,ect. Lorne
« Reply #4 on: February 14, 2008, 07:31:11 pm »
What are you in question about on how you installed your fuel pump?
Offline JJSZABO
« Reply #5 on: February 14, 2008, 09:07:08 pm »
This is the book I used to "finish" the crate motor
These are the instructions along with the instructions from the fuel pump:
This is the fuel pump:
The instructions say to install the fuel pump pushrod and then install the fuel pump so the pushrod pushes the fuel pump cam.  My concern is with this step.  When I finished and then spun the motor I didn't feel or hear anything from the pump.
It has been MANY years since I had to deal with a mechanical fuel pump.
« Last Edit: February 14, 2008, 09:12:20 pm by JJSZABO »
Jeff
86 Chevy C-10
350, TH400
Offline Redneckchevy
    • Photo Bucket
« Reply #6 on: February 14, 2008, 09:11:39 pm »
Well u gotta make sure the Rod Is on top of the fuel pump arm...U gotta hold the rod up there with some grease then install the fuel pump or else the rod will slip under the arm
Offline JJSZABO
« Reply #7 on: February 14, 2008, 09:14:05 pm »
That's what I "think" happened?  The rod was held in place with assembly lube while I installed the fuel pump - I even did it twice to be sure - maybe I am being paranoid? ::)
Jeff
86 Chevy C-10
350, TH400
    • Photo Bucket
« Reply #8 on: February 14, 2008, 09:18:42 pm »
Well if ur getting gas...it works.. if ur not then u no the rod dropped If u wanna make sure Get a inline clear fuel filter..
Offline JJSZABO
« Reply #9 on: February 14, 2008, 09:24:30 pm »
Hense the reason for wanting a fuel pressure gauge - If I have pressure it is installed correctly.
 I do not want to keep cranking the engine without it firing - do not want to damage the new cam.
Ahhh - good idea, didn't think of that ;)
Jeff
86 Chevy C-10
350, TH400
    • Photo Bucket
« Reply #10 on: February 14, 2008, 09:37:11 pm »
lol.....If you want to use a fuel pressure gauge u should...a lil eye candy dont hurt nothing...And if it makes u feel better knowing u got steady fuel pressure why not...Or try it my way....When ur clamps rot out and it starts to drip...just let it go...The Steady smell of gas and fumes rising from ur truck will also let you no....:D j/p
Offline werewolfx13
« Reply #11 on: February 14, 2008, 09:41:11 pm »
When I swapped my fuel pump, the new pump would NOT go back in when the rod dropped..I managed to hold the rod up and get the pump in place without using grease, but it wasn't my idea of fun.
Chris
'83 Chevy c10 Silverado SWB
« Reply #12 on: February 15, 2008, 10:01:54 am »
You can't get the pump on there if the rod dropped, well maybe with a large hammer.  If you installed it, as you said, it will be fine.
    • Photo Bucket
« Reply #13 on: February 15, 2008, 10:35:55 am »
I could of swore one time i installed one and it slipped under the arm....??
« Reply #14 on: February 15, 2008, 10:39:33 am »
If by some reason you did pull it off to get the pump on there with the rod dropped, it isn't going to do anything to the cam.  If you were able to I am impressed...
