Author Topic: gauges....Again...  (Read 33536 times)
Offline Redneckchevy
    • Photo Bucket
gauges....Again...
« on: February 23, 2008, 07:07:39 pm »
Ok need some help and info...I want to install new gauges in my truck "aftermarket" what do i need to do to set them? cut up the old one or buy a plate?? and what do i do with the factory stuff? like the blue sheet on the back of the old cluster? and do i just tap into the factory harness
Offline JJSZABO
Re: gauges....Again...
« Reply #1 on: February 23, 2008, 08:10:20 pm »
Hey Red :)
Go here and follow Jeff's install on gauges:
http://www.73-87.com/7387garage/garage_interior.htm
Jeff
86 Chevy C-10
350, TH400
    • Photo Bucket
« Reply #2 on: February 24, 2008, 06:49:45 pm »
Wanted to update this...I bought the white gauge over lays for my Fuel and speedo also bought a new set of white face sunpro gauges and a white face vacuum gauge..And a metal support for them that will replace the cheap plastic one on the original gauge cluster..So the after market will mount to the old cluster..I cut the plastic on the back and solder it together to reconnect the ground..Sine i will no longer be using the factory wires on new gauges and dont want the plastic hanging around...So when im done i will have new gauges and old all mixed in with eachother...Will post a pic later of my hack/chop/solder job on the old cluster
    • Photo Bucket
« Reply #3 on: February 24, 2008, 07:16:50 pm »
In this pics you will se before ande after i cut the plastic cheet striped back the plastic to expose bare copper...i then tined a wire and solderd it to the plastic with out melting anything i then took my meter to make sure it will work..and it does...
    • Photo Bucket
« Reply #4 on: February 25, 2008, 03:21:16 pm »
Ok well today i redid my harness so that my cluster will work....And i got every thing ware it needs to go...Only one thing i cant figure out....And its not in any manual i got or the stuff vile was able to supply....What color is the wire that is used for the Brake light??? Other then that i think i got this down..Since im not using any of the wires for temp/oil/amp..The wires that i could not figure out....So if any one can think of the color of that brake light wire please let me no...
« Reply #5 on: February 25, 2008, 06:44:31 pm »
It's not the tan with white?
    • Photo Bucket
« Reply #6 on: February 25, 2008, 07:44:59 pm »
only tan and white i got is 2 of them on one connector for my fuel gauge..Or so my Chilton book says?
    • Photo Bucket
« Reply #7 on: February 27, 2008, 05:07:55 pm »
Well today i got my metal bezel...Person that had it kinda did a cheesy way of cutting it for gauges he had in it..But it works well..I also received my kit from whitegauges.com will be installing that later on in the week...
Offline JRConnieK10
« Reply #8 on: February 27, 2008, 05:55:24 pm »
Dang man you get that all fixed you ain't goin to know how to act looks good though.
'85 K10 LWB 350/SM465
BUILT NOT BOUGHT
    • Photo Bucket
« Reply #9 on: February 27, 2008, 06:01:30 pm »
lol...yea i i haven't had working gauges in a long long time...When i test fitted it to the truck it looked flawless...Only thing i dont like is my vac gauge has that led controller with 2 knobs to control the color and it does this rain bow thing....all these settings just to get yellow...But that kit from whitegauges.com looks to be good quality tho...
Offline JJSZABO
« Reply #10 on: February 28, 2008, 08:30:46 am »
Congratulations on working gauges Red ;D
See, persistence does pay off :D :D
Jeff
86 Chevy C-10
350, TH400
    • Photo Bucket
« Reply #11 on: February 28, 2008, 03:20:46 pm »
Well cause i messed around and cared...then didnt care..i spent
3 Gauge clustet $150
Sun pro $40
Vac guage $20
White guage faces $20
Wire.$10
More solder $4
Tach $30
New Dash bezal $50 got mad and broke one!
And some more od and ends...If i would of just been clear headed i would of just bought the digital gauges from chris and had better looking gauges for almost the same price....But once you get in so deep your stuck so take a loss or keep on pushing
Offline JJSZABO
« Reply #12 on: February 28, 2008, 07:47:41 pm »
I am in the process of putting in Dakota Digital gauges (I bought from Chris :P) - Install is complete, finishing up with the rest of the wiring.
Jeff
86 Chevy C-10
350, TH400
    • Photo Bucket
« Reply #13 on: February 28, 2008, 07:50:08 pm »
Them are some sweet gauges!
« Reply #14 on: February 28, 2008, 08:04:12 pm »
I still have to put mine in!!!
