Author Topic: wiring  (Read 132352 times)
Re: wiring
« Reply #15 on: February 27, 2008, 01:12:56 pm »
Hotrod 24
You really need to elaborate on what you want to do or what you are trying to accomplish for anyone to offer up some solutions for you.
Offline hotrod24
Re: wiring
« Reply #16 on: February 27, 2008, 04:09:57 pm »
sorry vile i want it to be stock. my problem is the starter it must work because it cranks the truck, so my question is, do i need a new solenoid for the starter?
1978 pontiac grand prix...
Re: wiring
« Reply #17 on: February 27, 2008, 05:04:09 pm »
What is wrong with the starter if it cranks the truck?  If you want it back stock remove the solenoid on the firewall and run the wire on the junction that it was tied into back to the solenoid.
Offline hotrod24
Re: wiring
« Reply #18 on: February 27, 2008, 05:14:15 pm »
i thought sense there is a ford solenoid on it the starter solenoid might not work
Re: wiring
« Reply #19 on: February 27, 2008, 05:16:07 pm »
Still  ??? If you turn the ignition switch to the crank position does the truck start?
Offline hotrod24
Re: wiring
« Reply #20 on: February 27, 2008, 05:33:59 pm »
yes it does crank but i have to pat the gas old motor it is like it don't have  enough power
Re: wiring
« Reply #21 on: February 27, 2008, 05:38:11 pm »
If it turns the motor over your starter is fine.  If you have to give it gas for it to crank you have a fuel or spark problem.  Does it ever crank and run?
Offline hotrod24
Re: wiring
« Reply #22 on: February 27, 2008, 05:44:05 pm »
yes it will crack and run fine if i crank it and turn it off and Wait a minute it will crack right back up with out patting the gas
Re: wiring
« Reply #23 on: February 27, 2008, 05:45:42 pm »
lol, so what's the problem other than cheesy wiring?
Offline hotrod24
Re: wiring
« Reply #24 on: February 27, 2008, 06:36:40 pm »
well that is mostly it for the motor and the wiring would this help me any i would like to fix it now instead of later so i will not have to mess with it when i am restoring
http://www.chuckschevytruckpages.com/underhoodwiring.html
« Last Edit: February 27, 2008, 08:44:22 pm by hotrod24 »
Re: wiring
« Reply #25 on: February 28, 2008, 10:26:14 am »
Yes that diagram will help, but you just need to remove the Remote solenoid and put the stock on back in the loop.
So it is that you just don't like it then.  I was thinking that at first and then started thinking you had a problem cranking it...
Offline hotrod24
Re: wiring
« Reply #26 on: February 28, 2008, 01:37:30 pm »
yes i just want it stock and that solenoid off i like that clean look on the fire wall
Offline hotrod24
Re: wiring
« Reply #27 on: February 28, 2008, 04:44:42 pm »
here yall you can here this and see what you thank if there is anything that don't sound right or look right
Re: wiring
« Reply #28 on: February 28, 2008, 05:18:45 pm »
Sounds like you need to grease the hinges and adjust the striker on the door.
Offline hotrod24
Re: wiring
« Reply #29 on: February 28, 2008, 05:37:10 pm »
yea i know i replaced the door hinge and tried to align the door but did not work out
« Last Edit: February 28, 2008, 05:41:27 pm by hotrod24 »
