Author Topic: truck smoking  (Read 7388 times)
Offline hotrod24
truck smoking
« on: March 10, 2008, 11:18:50 pm »
This happen about 2 mouths ago i was taking my truck to get it inspected and some one was in front of me and they said thay could not even see my truck what could be the problem. my heads where full of oil so i stuck a screw driver in the holes and it went back down i thank that helped a little.So i need to know if this would be worth fixing right now because i am planing to rebuild another motor i have
« Last Edit: March 10, 2008, 11:24:34 pm by hotrod24 »
1978 pontiac grand prix...
Re: truck smoking
« Reply #1 on: March 11, 2008, 04:55:48 am »
where's the smoke? Tailpipe?
Offline hotrod24
Re: truck smoking
« Reply #2 on: March 11, 2008, 12:01:51 pm »
yep
Offline hotrod24
Re: truck smoking
« Reply #3 on: March 12, 2008, 09:48:16 pm »
well today i took it around the block and it was smoking again i don't know what it is it is coming out the tailpipes
« Last Edit: March 12, 2008, 09:50:17 pm by hotrod24 »
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: truck smoking
« Reply #4 on: March 12, 2008, 10:08:01 pm »
blue smoke, white smoke, purple smoke (oh, I 'm getting carried away)??
Check your oil to ensure there is no antifreeze getting in the oil pan.  YOu should be able to tell on your dipstick.  If so, you either have a head gasket problem or you have a crack in the block/head etc...
You can do a compression test on each cylinder--if it is blue smoke, you may have a valve seal messing up--or a broken ring on a piston.  I broke a piston ring one time on an engine I rebuilt when I was 16 (I didn't spend the money to bore it out correctly--I just honed it out)  and smoke was EVERYWHERE!  It did last a couple of years when money was hard to come by  ;)
Mason is dancin' again!! March Madness baby!
Offline ccz145a
Re: truck smoking
« Reply #5 on: March 12, 2008, 10:11:36 pm »
Yea, what color is the smoke?
Offline hotrod24
Re: truck smoking
« Reply #6 on: March 12, 2008, 10:29:48 pm »
white
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
Re: truck smoking
« Reply #7 on: March 12, 2008, 10:33:05 pm »
white?  check your dipstick as I mentioned earlier, for signs of H2O or antifreeze.
George Mason back in the NCAA big dance--final 4 bound yet again!
http://www.gomason.com
March Madness
Re: truck smoking
« Reply #8 on: March 13, 2008, 08:17:41 am »
If it's white smoke it's coolant or automatic transmission fluid.
Offline ccz145a
Re: truck smoking
« Reply #9 on: March 13, 2008, 10:14:22 am »
Starting with the cheapest fix:
If you have a TH40 or TH350, take off the vacuum hose at the modulator (side of the transmission) and see if any fluid is getting to the engine.
If that's not it, then you have coolant leak to the combustion chamber
Er, what Vile said.
Offline frogman68
Re: truck smoking
« Reply #10 on: March 13, 2008, 02:06:21 pm »
I remember this but wasnt there something about putting some oil in the cylinder and the recheck the compresion and if it goes up its one thing and if not the other ? (Valve seal or ring)
Offline hotrod24
Re: truck smoking
« Reply #11 on: March 19, 2008, 01:54:45 pm »
ok well now it is white blue you name it i think it is my valve sills
