Author Topic: 37 iroks  (Read 6862 times)
Offline 76 k10
37 iroks
« on: March 14, 2008, 01:20:54 pm »
i just bought some brand new 37/14.00/15 iroks. i have a 8 inch lift and a 12 bolt in the rear and a danna 44 in the front both with lockers now will i have any problems with these tires????
Re: 37 iroks
« Reply #1 on: March 14, 2008, 04:04:46 pm »
I guess you'll find out when you put them on....
If you have 8" lift I had 40"s with 9" lift
Offline JRConnieK10
Re: 37 iroks
« Reply #2 on: March 14, 2008, 04:40:37 pm »
Should fit fine if you want a little more clearence you can add a body lift.
'85 K10 LWB 350/SM465
BUILT NOT BOUGHT
Offline xtremjeepn
Re: 37 iroks
« Reply #3 on: March 14, 2008, 05:29:49 pm »
I run 37x12.50R17 MTRs on 4" of lift with Bushwhacker flares. Fit fine.
(note this truck was dismantled to put my crew cab together)
« Last Edit: March 14, 2008, 05:32:53 pm by xtremjeepn »
Cole
Restomod Crew Cab Short box on 37"s
Offline plowking_90
Re: 37 iroks
« Reply #4 on: March 14, 2008, 05:55:20 pm »
i have 6 inches of lift and 36 14.50 15 super swamper tsl radials on my 1980 gmc
Offline 76 k10
Re: 37 iroks
« Reply #5 on: March 14, 2008, 06:26:59 pm »
just got them on ;D they clear fine
Offline NevadaNeal
Re: 37 iroks
« Reply #6 on: March 25, 2008, 08:29:42 pm »
With that much rotating mass youl find out the week parts in the drivetrain.Most half ton drive train parts will hold up just fine until you push it to its limit's.Just food for thought.
Offline ssgoodman
Re: 37 iroks
« Reply #7 on: March 26, 2008, 05:33:30 pm »
would a 37 inch tire require bigger brakes or would the stock 1/2 tons work fine?
Offline xtremjeepn
Re: 37 iroks
« Reply #8 on: March 26, 2008, 07:47:46 pm »
My 37s are a a 1 ton with rear disks swapped in.
I would upgrade brakes personally.
Cole
