Author Topic: Break Lights/Wireing  (Read 16629 times)
Offline 197
« on: March 16, 2008, 09:09:57 pm »
Tonight I went to drive my truck 73' C20 454. When I turned the headlights on all I got was Headlights and front marker lights. No Flashers, Break, Tail or Blinkers. I replaced the brake light fuse and got brake lights and blinkers but still no Tail Lights?
Tips?
Anyone have a wiring digram?
'73 C20 454
Offline 76_Scottsdale
  • I'd rather push my Chevy than drive a Ford
Re: Break Lights/Wireing
« Reply #1 on: March 17, 2008, 01:02:41 am »
I would try replacing the flasher cans
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
True Dual 3" Flowmaster 40 Series Exhaust
Offline joesgarage71
  • Wrench
« Reply #2 on: March 17, 2008, 10:39:10 am »
  There might be a wire grounding out in the rear or on the frame to make the fuse blow. check the harness conections too.
« Last Edit: March 17, 2008, 10:41:03 am by joesgarage71 »
Offline 197
« Reply #3 on: March 17, 2008, 07:53:10 pm »
Update: When ingtion is on and I turn a blinker on they all flash like the hazzards. If I turn the headlights on with the blinker on it will either flash slow or go solid dim. With the light on I have front marker lights and headlights nothing else on the exterior.
Could it be the turn signal switch?
'73 C20 454
« Reply #4 on: March 17, 2008, 08:12:40 pm »
unplug the tail light connector and see what it does.
Offline 197
« Reply #5 on: March 17, 2008, 08:25:40 pm »
Did that, its getting power there.
'73 C20 454
« Reply #6 on: March 17, 2008, 08:28:00 pm »
no, unplug the rear harness connector near the tailgate. Then see what happens when you turn on your lights, signals etc. with the rear lamps out of the picture.
Offline 197
« Reply #7 on: March 17, 2008, 08:43:50 pm »
With the rear unpluged the front lights work like they should.
'73 C20 454
« Reply #8 on: March 17, 2008, 08:44:49 pm »
OK so check each bulb socket and make sure the ground wires at each side are clean and tight.
Offline 197
« Reply #9 on: March 17, 2008, 09:07:27 pm »
Thanks! It was the left side that wasn't grounded correctly.
'73 C20 454
