Electrical
Break Lights/Wireing
Topic: Break Lights/Wireing (Read 16632 times)
197
March 16, 2008, 09:09:57 pm »
Tonight I went to drive my truck 73' C20 454. When I turned the headlights on all I got was Headlights and front marker lights. No Flashers, Break, Tail or Blinkers. I replaced the brake light fuse and got brake lights and blinkers but still no Tail Lights?
Tips?
Anyone have a wiring digram?
'73 C20 454
76_Scottsdale
I'd rather push my Chevy than drive a Ford
Re: Break Lights/Wireing
March 17, 2008, 01:02:41 am »
I would try replacing the flasher cans
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
True Dual 3" Flowmaster 40 Series Exhaust
joesgarage71
Wrench
March 17, 2008, 10:39:10 am »
There might be a wire grounding out in the rear or on the frame to make the fuse blow. check the harness conections too.
Last Edit: March 17, 2008, 10:41:03 am by joesgarage71
197
March 17, 2008, 07:53:10 pm »
Update: When ingtion is on and I turn a blinker on they all flash like the hazzards. If I turn the headlights on with the blinker on it will either flash slow or go solid dim. With the light on I have front marker lights and headlights nothing else on the exterior.
Could it be the turn signal switch?
'73 C20 454
March 17, 2008, 08:12:40 pm »
unplug the tail light connector and see what it does.
March 17, 2008, 08:25:40 pm »
Did that, its getting power there.
'73 C20 454
March 17, 2008, 08:28:00 pm »
no, unplug the rear harness connector near the tailgate. Then see what happens when you turn on your lights, signals etc. with the rear lamps out of the picture.
March 17, 2008, 08:43:50 pm »
With the rear unpluged the front lights work like they should.
'73 C20 454
March 17, 2008, 08:44:49 pm »
OK so check each bulb socket and make sure the ground wires at each side are clean and tight.
March 17, 2008, 09:07:27 pm »
Thanks! It was the left side that wasn't grounded correctly.
'73 C20 454
Electrical
