Author Topic: Whats should I Buy For a Good Tune Up?  (Read 3958 times)
Offline forrest86c20
« on: March 20, 2008, 07:03:17 pm »
Hi, I'm new, I own a 1986 Chevy C20 HD Pickup with the Vin M 350
I'm wondering what should I buy to give this truck a basic tune up?
I've done the dizzy cap, Rotor, Oil, Coolant, ATF, Air Filter.
What should I get next? Plugs? Spark Plug Wires?, Fuel Filter?
Any Help I can get would be great!
Thanks
Re: Whats should I Buy For a Good Tune Up?
« Reply #1 on: March 20, 2008, 07:14:24 pm »
A major tune up consists of:
Plugs, Wires, Cap, Rotor, Fuel filter, Air filter, PCV valve, Breather, adjust timing, clean and adjust carb.
« Reply #2 on: March 21, 2008, 11:39:11 am »
Thanks For The Info!
By Chance would you have Info on changing the fuel filter?
I know it's in the carb, but is there anything beyond the filter I need to replace when I do it?
Thanks
« Reply #3 on: March 21, 2008, 10:28:21 pm »
You should only need a 1" open end, & a 5/8" line wrench. Once the line is off take the ( I call it ) the filter nut out, replace the filter same direction as the old one, put it back together. There is a spring behind the filter, just don't lose it.
« Reply #4 on: March 21, 2008, 11:13:54 pm »
Great Thanks for the help, it's been around 7 years since the filter was last done so I'm sure it's time
With Gas $3.67 A Gallon here I'm trying to squeeze every drop of fuel as far as I can
