Author Topic: Suspension lift inputs?  (Read 7946 times)
Offline Mamby
« on: March 24, 2008, 12:23:42 am »
Hi, i have a '85 k10, has a 4in BL and 36" superswampers. I would like to take my body lift out and get a suspension lift, but i'm not that great with trucks :S only dirtbikes  ;D Ive looked at some different skyjacker kits and nothing seems to be clicking for me, anyone know of a decent suspension lift that wont empty my bank account? thanks in advanced ;)
Re: Suspension lift inputs?
« Reply #1 on: March 24, 2008, 07:05:12 am »
Welcome from New Hampshaa Mamby.
I haven't shopped around for a kit in a while. I will say the more you get included in the kit, rear springs, steering arm, shocks, etc. the better off you will be in the long run. If you have to go back and purchase this stuff separate it will end up costing you more in $ and hassles in the end.
Offline Swims350
    • Cars and trucks
« Reply #2 on: March 24, 2008, 10:50:18 am »
jcwhitney has 2 nice ones, one rough country with shocks steering arm front springs, bushings, and rear blocks and u bolts for about $300 I got mine shipped for that price.
They also have tuff country with ez ride springs and it's got all the same stuff for about $360 and definately the way to go unless you like a rough ride and harsh ride on the rode, let alone on the trails.
rough country is rough and willbeat you to death.
www.cardomain.com/id/benwa454
Offline Mamby
« Reply #3 on: March 24, 2008, 08:57:10 pm »
sweet, thanks for the inputs, ill check out jcwhitney and see what they have.
« Reply #4 on: March 25, 2008, 05:01:29 am »
There's a lot of different ways to do it.
Cheapest way out will be 6" springs and rear blocks but I'd go all spring...just use google like this search
http://www.google.com/products?q=6%22+suspension+lift+1973&hl=en&show=dd
Offline Mamby
« Reply #5 on: March 30, 2008, 12:19:06 am »
awesome, so if i bought this kit (http://store.4wheelingplus.com/proddetail.asp?prod=125H&source=froogle) i would have everything needed to lift my truck?
« Reply #6 on: March 30, 2008, 11:55:28 am »
yes sir
Offline Swims350
    • Cars and trucks
« Reply #7 on: March 30, 2008, 12:45:00 pm »
that looks the same as our 4 inch but has 6 inch springs and add a leafs for back plus blocks.
just an FYI we needed the sway bar drops in order to bolt it up and they are required for a 6 inch lift or bigger, but we had 4 and had to get them, brake lines are needed, and transfer case drop bracket are supposed to be needed as well for older truck we had 86, or more lift then 4 inches.
If you don't mind a really rough harsh ride I'd go with it, but if you want smooth ride look into ez ride from tuff country or the softride from superlift or skyjacker forget which.
Offline ssgoodman
« Reply #8 on: March 30, 2008, 05:16:25 pm »
check out off road designs lift kit, i have no clue on the price for it but it doesnt require the blocks in the back instead usings a shackle flip.
Offline asbuilt77
« Reply #9 on: April 16, 2008, 10:39:16 am »
Check out ROUGHCOUNTRY.com they offer some good lifts at affordable prices! Had a 2" kit on my truck that flexed 36" all day! I was very pleased with a 25yr old lift that kept its shape!
Offline BILTUP
« Reply #10 on: April 19, 2008, 09:10:27 pm »
Do not use rough country, they are just that, rough.  Tuff country is excellant and a shackle flip in the rear is the best way to go.  I run tuff country 6'' in front and ORD shackle flip in back.
