Author Topic: 350 to a 327  (Read 6942 times)
Offline 75 C20
350 to a 327
« on: March 31, 2008, 04:28:05 pm »
would it work to put a 327 crank in a 350 block and then have a 327? i thought i read that it would work and i also thought i read the 307 crank is the same as a 327 crank? i figured it would work since a 350 and 327 both have 4 in bores but im no mechanic so i thoughti'd ask :P
1975 Custom Deluxe 20 350 SM465 2WD Longbed
1979 Custom Deluxe 20 400 SM465 2WD Longbed
1968 Custom Sport Truck 20 327 TH400 2WD Longbed
1985 Silverado 10 305 700R4 2WD Longbed
1969 Pontiac GTO 400 Turbo350
2008 GMC 2500HD 6.0 6spd 4X4 Longbed
Re: 350 to a 327
« Reply #1 on: March 31, 2008, 04:30:51 pm »
The pistons aren't the same, so you would need them.
Also there are 2 types of 327 cranks.  small and large journal.  All 350's are Large Journal (as are 307's)
Offline HAULIN IT
Re: 350 to a 327
« Reply #2 on: March 31, 2008, 04:34:37 pm »
To add to what the Capt. said. The '68 & '69 327's are the large journal ones (same as the 307). The ones '67 & earlier to that were small journal. Lorne
Offline 75 C20
Re: 350 to a 327
« Reply #3 on: March 31, 2008, 04:39:42 pm »
yeah i was aware of the journal size on 327s
but are all 307s large journals?
Re: 350 to a 327
« Reply #4 on: March 31, 2008, 04:42:36 pm »
yeah, look up.. :D ALL 307's are large journals..
Offline 75 C20
Re: 350 to a 327
« Reply #5 on: March 31, 2008, 05:18:17 pm »
lol sometimes i can confuse myself
Offline 1976Scottsdale
Re: 350 to a 327
« Reply #6 on: April 02, 2008, 09:54:44 pm »
Just did this job.  The pistons are different as are the balancer and timing cover, other than that the rods and everything else will all swap.  It revs quick, just keep it in a half ton, not quite enough low end for a 3/4 or 1 ton.
Offline 76_Scottsdale
  • I'd rather push my Chevy than drive a Ford
Re: 350 to a 327
« Reply #7 on: April 02, 2008, 10:04:01 pm »
An old friend of mine did that and ran it with dual quads in a '55 chevy and ran high 10's. That thing freaking screamed.
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
True Dual 3" Flowmaster 40 Series Exhaust
Re: 350 to a 327
« Reply #8 on: April 03, 2008, 08:58:12 am »
Trust me, they do scream.  They just don't pull quite so well on the low end as a 350 or a 383, but they are still a very good engine.
Re: 350 to a 327
« Reply #9 on: April 03, 2008, 10:17:59 am »
327's work well for offroad racing with your transfercase in low range and a set of 4.56 gears... I don't think I'd like one for streetability though
Re: 350 to a 327
« Reply #10 on: April 03, 2008, 10:58:40 am »
From experience I can definitely second that one.  Don't get me wrong it was very fast, it just did not have enough to make me comfortable with a heavy trailer behind it.  If you are going to play in the mud it would befine for that, but it is more economical to build a 350, you pay half as much and have twice the motor.
Offline 75 C20
Re: 350 to a 327
« Reply #11 on: April 03, 2008, 09:05:12 pm »
it would be going in a 3/4 ton 68 chevy wit ha th400 tranny and 4.10 rearend? wut u think
Offline Fordeatinz71
  • 78k miles and counting
Re: 350 to a 327
« Reply #12 on: April 03, 2008, 10:28:45 pm »
as long as you don't need it for a lot of low end power, go for it.  if you need to move heavy loads then i'd stick with something with more low-end grunt.  it depends on what you do with your truck...
