Author Topic: Gas tank question  (Read 4490 times)
Offline chronos
Gas tank question
« on: April 06, 2008, 05:22:28 pm »
Does anyone know if you can use a fullsize box gas tank in a shortbox?? If not why??
My current tank is out now-
what a PITA that was!!
The tank i took out is 44" long
I assume my old tank is 16 gallon , will the 20 gallon fit with the shortbed?
« Last Edit: April 06, 2008, 05:39:52 pm by chronos »
Re: Gas tank question
« Reply #1 on: April 06, 2008, 05:43:44 pm »
No it won't fit. You can put 2 16 gallon tanks in though.
Offline chronos
« Reply #2 on: April 06, 2008, 07:29:40 pm »
Thanks VZ, i have a parts truck with dual long tanks.
is this a 'easy' do into my facory single tank short bed??
Of course I would need 2 short tanks for mine. Can i make this work with a single door box?
« Reply #3 on: April 06, 2008, 07:34:50 pm »
yeah I had my truck set up with a cross feed. Tank A has filler. Tank B feeds carburetor. Tank B has active fuel gauge. Fill tank A then flip on the switch to pump tank A into tank B. You have to watch the gauge. The refill tank a and u have 2 full tanks. It's kinda hokey but works.
Offline chronos
« Reply #4 on: April 06, 2008, 08:15:10 pm »
Thanks VZ. I think i will stick with the one tank.
Do I have any other options on a larger tank??
« Reply #5 on: April 06, 2008, 09:27:20 pm »
yeah if you wanna locate it to the back and use a blazer tank
« Reply #6 on: April 07, 2008, 02:30:46 pm »
This is my write-up on how to put a Blazer tank in the back of a SWB pickup:
http://www.captkaoscustoms.com/blazertank.html
