73-87 Chevy & GMC Trucks
dual gas tanks
Topic: dual gas tanks (Read 22772 times)
hotrod24
Re: dual gas tanks
Reply #15 on:
May 01, 2008, 08:05:13 pm »
you know it is a funny thing i have a filter by the carb to what do i do
Last Edit: May 01, 2008, 08:14:14 pm by hotrod24
1978 pontiac grand prix...
Re: dual gas tanks
Reply #16 on:
May 02, 2008, 09:46:21 am »
There should be lines running down the passenger side of the framerail and terminating before the tank. On the same side should be your gas tank with a sending unit on the top. take a hose and run it from the sending unit to the appropriate fuel line.
What you have isn't factory, it should have metal lines across the back....
ccz145a
Re: dual gas tanks
Reply #17 on:
May 02, 2008, 10:47:11 am »
Quote
My '75 had factory rubber lines still in place and in good shape when I pulled the cab off last summer.
But your right in that this setup is not factory. Rubber lines can last a while in this area, they need to be fastened and protected correctly.
I like the hard line setup better, so before I put my cab back on I put on the set from my donor.
hotrod24
Re: dual gas tanks
Reply #18 on:
May 22, 2008, 08:42:31 pm »
today i took my passenger side tank off i know i should have took the drivers side off but for now i just wanted to take this one off and i said before that my passenger side tank did not work well i started looking and the hoses was cut off the only thing that was hooked to it was the ground wire oh and i took the gas selector off well i think that is what it is
hotrod24
Re: dual gas tanks
Reply #19 on:
May 23, 2008, 03:34:24 pm »
hey what gallon is in are trucks i think i have a 16 gallon
Re: dual gas tanks
Reply #20 on:
May 23, 2008, 05:23:44 pm »
yes it's 16 gallon
hotrod24
Re: dual gas tanks
Reply #21 on:
May 23, 2008, 09:01:16 pm »
where could i get a sending harness for a gas tank
Re: dual gas tanks
Reply #22 on:
May 23, 2008, 09:02:57 pm »
What's a sending harness?
hotrod24
Re: dual gas tanks
Reply #23 on:
May 23, 2008, 09:20:29 pm »
sorry vile it goes to your sending unit that is in your gas tank and this is all that i could find but it is for 67-72
http://www.classicparts.com/prodinfo.asp?number=52-817
Last Edit: May 23, 2008, 10:44:38 pm by hotrod24
Re: dual gas tanks
Reply #24 on:
May 24, 2008, 07:10:52 am »
For the sending unit it's just one wire.
dual gas tanks
