Author Topic: dual gas tanks  (Read 22758 times)
Offline hotrod24
Re: dual gas tanks
« Reply #15 on: May 01, 2008, 08:05:13 pm »
you know it is a funny thing i have a filter by the carb to what do i do
« Last Edit: May 01, 2008, 08:14:14 pm by hotrod24 »
1978 pontiac grand prix...
Re: dual gas tanks
« Reply #16 on: May 02, 2008, 09:46:21 am »
There should be lines running down the passenger side of the framerail and terminating before the tank.  On the same side should be your gas tank with a sending unit on the top.  take a hose and run it from the sending unit to the appropriate fuel line.
What you have isn't factory, it should have metal lines across the back....
Offline ccz145a
Re: dual gas tanks
« Reply #17 on: May 02, 2008, 10:47:11 am »
Quote
My '75 had factory rubber lines still in place and in good shape when I pulled the cab off last summer.
But your right in that this setup is not factory. Rubber lines can last a while in this area, they need to be fastened and protected correctly.
I like the hard line setup better, so before I put my cab back on I put on the set from my donor.
Offline hotrod24
Re: dual gas tanks
« Reply #18 on: May 22, 2008, 08:42:31 pm »
today i took my passenger side tank off i know i should have took the drivers side off but for now i just wanted to take this one off and i said before that my passenger side tank did not work well i started looking and the hoses was cut off the only thing that was hooked to it was the ground wire oh and i took the gas selector off well i think that is what it is
Offline hotrod24
Re: dual gas tanks
« Reply #19 on: May 23, 2008, 03:34:24 pm »
hey what gallon is in are trucks i think i have a 16 gallon
Re: dual gas tanks
« Reply #20 on: May 23, 2008, 05:23:44 pm »
yes it's 16 gallon
Offline hotrod24
Re: dual gas tanks
« Reply #21 on: May 23, 2008, 09:01:16 pm »
where could i get a sending harness for a gas tank
Re: dual gas tanks
« Reply #22 on: May 23, 2008, 09:02:57 pm »
What's a sending harness?
Offline hotrod24
Re: dual gas tanks
« Reply #23 on: May 23, 2008, 09:20:29 pm »
sorry vile it goes to your sending unit that is in your gas tank and this is all that i could find but it is for 67-72
http://www.classicparts.com/prodinfo.asp?number=52-817
« Last Edit: May 23, 2008, 10:44:38 pm by hotrod24 »
Re: dual gas tanks
« Reply #24 on: May 24, 2008, 07:10:52 am »
For the sending unit it's just one wire.
