Author Topic: dual gas tanks  (Read 22747 times)
Offline hotrod24
dual gas tanks
« on: April 13, 2008, 12:03:18 am »
ok i have dual gas tanks on my truck and i dont have a way to switch them i was going to wire up a switch and use them but i decided to just go with one so how would i take the passenger side tank off and just use one of them
« Last Edit: May 01, 2008, 06:18:25 pm by hotrod24 »
1978 pontiac grand prix...
Offline 77c15
  • combustion=suck, squeeze, bang, blow
    • My cardomain site...
Re: dual gas tanks
« Reply #1 on: April 13, 2008, 05:43:41 am »
You can still get the switch from GM. Check the local dealership before you go removing the "other" tank and have to remove/reroute the hoses, etc.
Offline hotrod24
Re: dual gas tanks
« Reply #2 on: April 13, 2008, 11:15:57 am »
well you know 77 i dont have a hole to put a switch in i think who ever had the truck before me put dual tanks on it and forgot to put a switch in
Re: dual gas tanks
« Reply #3 on: April 13, 2008, 12:37:57 pm »
Hot rod, if you wanted to run 2 tanks you could mount a switch just about anywhere you want too. Look under the dash to see if the tank switch harness is there. Is the tank switching valve installed between the two tanks?
Offline hotrod24
Re: dual gas tanks
« Reply #4 on: April 13, 2008, 01:03:30 pm »
yes every thing between the two tanks is there but i do not see a harness for the switch
Offline 80stepsideguy
Re: dual gas tanks
« Reply #5 on: April 13, 2008, 02:23:01 pm »
Dusty,
make life simple, tear that truck down to a bare cab, take everything and i mean everything off, the front clip, the bed, the doors, the electricial EVERYTHING and start over from scratch.Buying a truck in the condition yours is in i say start from the ground up.You`ll be chasing them gremlins for a long time unless you start from a clean slate.Take all the bolts, put them in bags, label them and put them in a box where you know they`ll be in.Same goes for the harness, label every connection and go from there.I say replace that harness and go with a painless performance harness.
thanks
pat
1998 Chevy 1500 S/B 2wd
Offline hotrod24
Re: dual gas tanks
« Reply #6 on: April 13, 2008, 02:36:47 pm »
pat that is exactly what am going to do when i get a shop everything is coming off but sense i dont have a shop would be a good idea to take the bed off and fix my gas tanks so i am just using one so i want have more to do when i get a shop
Offline hotrod24
Re: dual gas tanks
« Reply #7 on: April 14, 2008, 02:21:59 pm »
well i made up my mine i am going with one gas tank where should i start i am going to unbuilt the bed and take it off and then i will convert to one gas tank
Re: dual gas tanks
« Reply #8 on: April 14, 2008, 02:26:15 pm »
Use the one on the passenger side, You just need the hose to to connect to the tank and original lines.
Offline hotrod24
Re: dual gas tanks
« Reply #9 on: April 14, 2008, 02:37:26 pm »
chris what is the difference in using the passenger side or the driver side i would like it to be stock
Quote from: Captkaos link=topic=8170.msg51877#msg51877  date=1208201175
« Last Edit: April 14, 2008, 02:51:06 pm by hotrod24 »
Re: dual gas tanks
« Reply #10 on: April 14, 2008, 03:27:09 pm »
Because the fuel lines run down the pasenger side. Make it eisier to hook up the tank instead of running mor eline to the other side.
Re: dual gas tanks
« Reply #11 on: April 14, 2008, 03:33:23 pm »
What he said... :D
Offline hotrod24
Re: dual gas tanks
« Reply #12 on: April 14, 2008, 03:40:28 pm »
what do i have to do to switch to one tank where do i start any advies
« Last Edit: May 01, 2008, 06:17:36 pm by hotrod24 »
Offline hotrod24
Re: dual gas tanks
« Reply #13 on: May 01, 2008, 06:20:52 pm »
what is a good way to get the gas out of the filter
« Last Edit: May 01, 2008, 06:24:44 pm by hotrod24 »
Offline ccz145a
Re: dual gas tanks
« Reply #14 on: May 01, 2008, 07:51:33 pm »
Back up a few feet and snap the pic again,and get a pic of the gas valve just infront of the xmember at the bottom of the photo, that is if it there. It's on the pass side. What is there does not look stock and need to see more. That is not a good place for the filter, it needs to be downstream of the fuel pump, near the carb.
EDIT** I just remembered that the xmember I am talking about is under the cab (my cab was off when I rerouted mine)
Just dump the gas in the filter, if you have to. But why do you need to? You could put it in your lawnmower.
« Last Edit: May 01, 2008, 07:55:42 pm by ccz145a »
