Author Topic: Safe to splice ground wire from sending unit??  (Read 6565 times)
Offline chronos
« on: April 21, 2008, 07:31:22 pm »
One more thing to figure out before I get my tank back in:
Can I splice together the ground wire coming off the new
sending unit into the existing ground wire that went into the old one?
Seems OK to me , but thought I'd check for some input.
Thanks
Re: Safe to splice ground wire from sending unit??
« Reply #1 on: April 21, 2008, 08:23:08 pm »
 ??? If you have a new sending unit why do you need to splice the ground wire?
Offline Bitzer!
  • Smiles per gallon
« Reply #2 on: April 22, 2008, 03:34:45 pm »
Why not just junk anything old and fit new anyway? That way you'll know its good ;)
1979 GMC CrewCab  C20 1t
« Reply #3 on: April 22, 2008, 04:44:26 pm »
I would price a new one. What you have to consider is that even if it ohms out ok, it still may not work with a load , even though it is so minimal.
Offline 77 step
« Reply #4 on: April 22, 2008, 11:23:40 pm »
Price a new ground wire?  I guess it depends on the gauge, but I would bet price is not an issue.  :D
I would guess you could with out any problems...except... what if the reason your last sender was inaccurate was a bad ground?
I would run new, if it were mine.
Good luck!
Sean
1977 K-10 stepside under slow reconstruction.
« Reply #5 on: April 23, 2008, 11:10:46 pm »
I meant new sending unit ::) ;)
Offline HAULIN IT
« Reply #6 on: April 24, 2008, 07:29:33 am »
Chronos, I believe each guy in there own way is wanting to get around to asking..."Have you looked how long & where the ground wire goes?" Just remove the 1/2"-13mm bolt, clean up the frame where the ring sits, put the new one on & put some grease on it when your done to prevent corrosion. Lorne
Offline 77 step
« Reply #7 on: April 24, 2008, 09:26:12 am »
I figured you did... he said in the original post he had a new one.  Sorry for the poke, though, I couldn't resist. ;D
Sean
