Author Topic: Drive Shaft questions  (Read 5439 times)
Offline ssgoodman
« on: May 11, 2008, 11:54:18 pm »
Do you need to lengthen your drive shafts when putting lift kits?  and/or when do you need to put a spacer on the transfer case?
Sutton
Re: Drive Shaft questions
« Reply #1 on: May 12, 2008, 05:02:11 am »
How much are you lifting it?
« Reply #2 on: May 12, 2008, 06:41:05 am »
I have never lengthened a shaft for any lift under 4". If you start getting into 6" it when it is an issue. I usually put spacers in starting at 2' or 3" of lift. Just to help the shaft angle. I have read you don't need them until 4" or more.
Offline 76 k10
« Reply #3 on: June 12, 2008, 01:24:13 am »
i have a 8 inch lift and i havnt done anything to my driveline
