Engine/Drivetrain
Transmission problem help
Topic: Transmission problem help (Read 5870 times)
three8six
May 16, 2008, 03:10:41 pm »
I have a 86 SWB 4.3 v6, with a th375. I just had the transmission rebuilt by a well respected guy and the 1st tiem we ran it it didnt leak then it started leaking very slowly out of the pan . Well today we pulled the pan off to replace the cork gasket with a rubber one. We noticed that the filter is hanging down quite a ways on the bolt and the bolt seems tight but it also is pushing on the pan(so much so that its made a dent in the pan where it was located. I need to know is that normal? And does anybody have suggestions as far as bolt size? I havent tried to torque down any harder for fear of more damage? Any help is very appreciated?
Re: Transmission problem help
May 16, 2008, 03:20:47 pm »
The filter has a pipe with 2 o-rings and then it just hangs on that bolt loose like that. The bolt shouldn't hit the pan however. Did you once have a deep pan and now a shallow pan?
three8six
May 17, 2008, 04:49:00 pm »
See I dont really know. I thought it was the same pan off of my transmission. This guy though i ended up giving him 3 transmissions,(just for multiple core charges) that I had laying around(a 4l60e, a th350, and a th400). So I mean maybe he put the wrong bolt in it? Is that the most likely cause of this problem?
May 18, 2008, 12:36:17 pm »
Not if it had a deep pan and he put a shallow pan on it.
three8six
May 18, 2008, 04:05:19 pm »
Naw its def. the deep pan. The bolt is just barely to long. i mean like 1/8 of an inch at most. What would be tghe worst case scenario of putting a short pan bolt in it anyways though?
May 18, 2008, 07:53:44 pm »
Just get a new bolt or a new deeper pan.
Blazin
Blazin new trails!
May 20, 2008, 05:41:49 am »
Just my .02, but if he knows what he is doing why isn't he trying some fixes/
What about cutting some off the bolt?
ccz145a
May 20, 2008, 07:52:14 am »
...or dimple the pan a little if it is barely touching.
Engine/Drivetrain
