Author Topic: head light harness  (Read 41090 times)
Offline frogman68
Re: head light harness
« Reply #30 on: June 23, 2008, 06:10:05 pm »
I see a extra standoff on the top one between the oil pressure and speedo
« Reply #31 on: June 23, 2008, 08:08:52 pm »
BTW, I am wondering why you are even considering changing clusters as they are identical as far as gauges offered?   ???
That's because someone broke it off...
Offline hotrod24
« Reply #32 on: June 24, 2008, 01:05:40 pm »
the old is broke so that why i had to change and it would never fit right
                                      new one
                                       old one
« Last Edit: September 23, 2008, 07:57:56 pm by hotrod24 »
1978 pontiac grand prix...
Offline ccz145a
« Reply #33 on: June 24, 2008, 01:54:31 pm »
The circuit boards are identical. I think that is what we were trying to find out, right?
Offline hotrod24
« Reply #34 on: June 24, 2008, 02:33:59 pm »
yea and if i can use the new in my 78
Offline ccz145a
« Reply #35 on: June 24, 2008, 02:43:17 pm »
Did your old one ever work? If so, it looks like you should have no troubles, then.
Offline hotrod24
« Reply #36 on: June 24, 2008, 03:32:43 pm »
yes it worked but it is broke
« Reply #37 on: June 24, 2008, 04:03:39 pm »
Same cluster.  1978-80.  You could swap everything over to the housing if you wanted...
Offline hotrod24
« Reply #38 on: June 24, 2008, 04:20:38 pm »
so both of my clusters are 78-80
« Reply #39 on: June 24, 2008, 04:27:02 pm »
yes, that is correct.
If it was a 77 cluster, you would see a hole where the oil pressure gauge it for a metal line to connect to.
Offline hotrod24
« Reply #40 on: June 24, 2008, 07:41:20 pm »
why do i have a hole where my battery gauge is it is on both of them
« Last Edit: June 24, 2008, 07:45:35 pm by hotrod24 »
Offline ccz145a
« Reply #41 on: June 24, 2008, 09:09:55 pm »
An ammeter would have used that hole and the top one would be empty. But the connector would have been + instead of ground. Your whole system's current would be flowing thru the meter. That is why you can't use an ammeter circuit panels with the voltmeters and visa versa AND why so many questions were asked before we told you it would work. sizzle, sizzle.
« Last Edit: June 24, 2008, 09:11:43 pm by ccz145a »
Offline hotrod24
« Reply #42 on: June 24, 2008, 09:40:54 pm »
 i am just trying to make sure that if i get a new dash harness everything will work
« Last Edit: June 24, 2008, 09:52:29 pm by hotrod24 »
Offline ccz145a
« Reply #43 on: June 24, 2008, 10:00:47 pm »
I just re-read my post... It could have been read as a sarcastic response, but I did not mean it that way. You have put a lot of work into your truck, and I want to see you succeed, too.
Offline hotrod24
« Reply #44 on: June 24, 2008, 11:06:03 pm »
thanks man i have worked hard but i did not take it that way you was just trying to help out
