Author Topic: head light harness  (Read 41088 times)
Offline hotrod24
head light harness
« on: June 16, 2008, 03:38:31 pm »
today i cut my head light harness from the fuse box if i got a new harness would it wire right up to it i have been taking stuff off that i know i will probably use again.
1978 pontiac grand prix...
Re: head light harness
« Reply #1 on: June 16, 2008, 03:46:14 pm »
Why did you cut it.  it will ubolt/unclip off of that.
Offline ccz145a
« Reply #2 on: June 16, 2008, 03:47:04 pm »
Your talking in the engine compartment? Could have unbolted the connector and removed just the front light harness connector (the middle one)
My 75 two headlight harness mated right up to my new 84 cab's connector.
Offline hotrod24
« Reply #3 on: June 16, 2008, 04:15:04 pm »
oh i am getting a new dash harness and engine harness so i am covered it was all hack up anyway.
« Last Edit: June 18, 2008, 02:44:41 pm by hotrod24 »
Offline hotrod24
dash harness
« Reply #4 on: June 18, 2008, 01:55:03 am »
today i called american auto wire to ask about a dash harness and they ask me do you have gauges or warning lights and i said i have both but he told me that i have gauges so which one do i have and what is the differences.
« Last Edit: June 18, 2008, 02:48:53 pm by hotrod24 »
« Reply #5 on: June 18, 2008, 04:17:31 pm »
If that is your cluster, you have Gauges.  I would tell them you have the brake warning light in the bottom right just to let them know.
Offline hotrod24
« Reply #6 on: June 18, 2008, 04:19:53 pm »
yea it is mine what is the difference in gauges or warning lights
Offline HAULIN IT
« Reply #7 on: June 18, 2008, 04:40:58 pm »
Hotrod, The wiring would be different to work a gauge than having a warning lamp come on signaled from a sending unit, just as the sending units themselves are different. Also the placement of the pins on the plug going into the circuit board are different because of the different placement of the warning lights & Brake light, ect. as was mentioned.   Lorne
Offline hotrod24
« Reply #8 on: June 18, 2008, 04:51:14 pm »
ok i understand now how hard would it be to get my warning light to work that is on my cluster
« Reply #9 on: June 18, 2008, 05:27:51 pm »
If they sell you a factory harness (assuming you are buying a harness that matches the truck with that cluster matching the truck also) it should work.
What year is the truck?
What year is the harness you plan to order for?
What year is that cluster from?
Offline hotrod24
« Reply #10 on: June 18, 2008, 05:37:45 pm »
my truck is a 78 and i was going to order a harness for a 78 and the cluster i have is from a 77 will it work.
« Last Edit: June 18, 2008, 07:43:26 pm by hotrod24 »
Offline ccz145a
« Reply #11 on: June 18, 2008, 08:10:39 pm »
that ought to work just fine.
« Reply #12 on: June 18, 2008, 10:01:05 pm »
76-77 is the same (mech oil sender) is that what the cluster is?
78-up is the same (all electrical)
Are you getting the complete harness?
Offline hotrod24
« Reply #13 on: June 18, 2008, 10:47:13 pm »
yea i am going to wire my whole truck with american auto wire
« Last Edit: June 18, 2008, 11:20:45 pm by hotrod24 »
« Reply #14 on: June 19, 2008, 12:48:31 pm »
How much is that going to cost you?  If you do that and want to use that cluster, get one for a 77...
Last time I checked a Painless system was cheaper...
