Author Topic: 454 Thumpr Cam Kit  (Read 5969 times)
Offline ccz145a
454 Thumpr Cam Kit
« on: June 19, 2008, 10:17:45 am »
Anyone have opinions or experiences about this thumpr cam from comp cams?
http://store.summitracing.com/partdetail.asp?part=CCA%2DK11%2D600%2D8&autoview=sku
specs from comp cams site:
http://www.compcams.com/Cam_Specs/CamDetails.aspx?csid=485&sb=2
Will it work well with a lwb fleet side ~5500lbs th400 3.42 rear?
« Last Edit: June 19, 2008, 10:53:23 am by ccz145a »
Offline SUX2BU99
Re: 454 Thumpr Cam Kit
« Reply #1 on: June 19, 2008, 11:28:44 am »
Generally speaking, those Thumper cams are pretty expensive for what benefit I'm not sure. Perhaps they are only roller cams. I think you can get the same everything for less, even within the CompCams catalogue. Look at their Xtreme Energy or XE4x4 lines to compare.
Offline ccz145a
« Reply #2 on: June 19, 2008, 03:07:50 pm »
comp cams had this audio: http://www.compcams.com/Base/MultiMedia/SoundBytes/Thumpr/Thumpr.wma
I was looking for a roller since I still have an annoying valve train tap even after replacing liters and checking for bent push rods and adjusting.
I will definately try adjustment again before I buy anything. But if it turns out to be a rounded lobe, I will go with a roller.
« Reply #3 on: June 19, 2008, 09:19:50 pm »
I would not run that cam!
Offline ccz145a
« Reply #4 on: June 20, 2008, 07:49:23 am »
Quote
Quote
Yeah, I see your point after playing with comp cams's little desktop simulator/cam picker app.
There are better cam grinds, thanks for the input.
Offline lowriderbowtie
« Reply #5 on: June 22, 2008, 03:09:43 pm »
from my experience, the thumpr cams are for sound only.
I tried a thumpr in my old s10 with a 355 in it..not impressed.
1976 3/4T Camper Special
350, LT headers, H pipe, Dynomax bullets, 4/3 drop
