Author Topic: Transfer Case  (Read 14050 times)
Offline qboy
Transfer Case
« on: June 21, 2008, 12:28:34 am »
I've got a 1975 GMC K15 short bed 4x4.   How can I tell if I have an NP203 or an NP205 transfer case?
1975 K15 GMC 1/2 ton SWB 4x4 383 (stroked 350), turbo 350 tranny
Re: Transfer Case
« Reply #1 on: June 21, 2008, 01:39:17 am »
What's your shift pattern? Look on the back of the transfer case for a tag. Is there an aluminum extension housing or is it all cast iron?
Offline joesgarage71
  • Wrench
Re: Transfer Case
« Reply #2 on: June 21, 2008, 11:33:18 am »
 If it has a drain plug its a 205
If not a 203
Offline blast
    • JamRoom
Re: Transfer Case
« Reply #3 on: June 22, 2008, 10:45:28 am »
Offline 87GMC2WD
Re: Transfer Case
« Reply #4 on: June 22, 2008, 04:01:49 pm »
what other kind of transfer cases are there. i dont have either of those two.
Re: Transfer Case
« Reply #5 on: June 22, 2008, 09:09:40 pm »
Did you look for the tag? Take a pic
Offline 76_Scottsdale
  • I'd rather push my Chevy than drive a Ford
Re: Transfer Case
« Reply #6 on: June 22, 2008, 09:32:10 pm »
87GMC2WD
You may have a NP208. Check out that page to see what you have.
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
True Dual 3" Flowmaster 40 Series Exhaust
Re: Transfer Case
« Reply #7 on: June 22, 2008, 09:59:09 pm »
208s were not offered until 81, 82 ish.
Offline Fordeatinz71
  • 78k miles and counting
Re: Transfer Case
« Reply #8 on: June 23, 2008, 07:44:29 am »
yes but lets remember swaps do happen...
Re: Transfer Case
« Reply #9 on: June 23, 2008, 08:06:55 am »
Yes, but not useually a down grade!!!!! :P
Offline 87GMC2WD
Re: Transfer Case
« Reply #10 on: June 23, 2008, 03:18:33 pm »
well i have a 83 blazer and a 84 k20. the blazer i just got and is only a rolling chassis. that transfer case has a NP tag on it that i think says 203. the truck has no tag w/ 2hi 4hi n 4low.
Offline Donut
Re: Transfer Case
« Reply #11 on: June 23, 2008, 06:50:57 pm »
Is the transfer case alum or cast iron?
2hi 4hi n 4low.  that's the shift pattern, might be on the TC shifter knob.  The link Blast gave you helped me identify mine.
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
Offline 87GMC2WD
Re: Transfer Case
« Reply #12 on: June 23, 2008, 08:05:38 pm »
i looked at the tag again i think that it might be a 208. cleaned it with some brake clean and it looks more like an 8.
Blazin, you said the 208's are a downgrade. what is the difference and why are they worse.
Offline blast
    • JamRoom
Re: Transfer Case
« Reply #13 on: June 23, 2008, 08:28:03 pm »
here's a np208, does it look like this?
Re: Transfer Case
« Reply #14 on: June 23, 2008, 08:49:45 pm »
They're not a gear drive unit but for regular street and offroad use they're great. If you are a serious offroader not so good.
