Interior & Equipment
interior paint
Topic: interior paint (Read 16057 times)
79diesel
interior paint
June 25, 2008, 07:31:32 pm »
well since none of my interior panels seem to be the same shade i was wondering if anyone knew of a good paint or dye to use on the interior to get everything matched up?
heres a pic of the interior colour
thanks
hotrod24
Re: interior paint
June 25, 2008, 07:58:19 pm »
here you go i did this all with wallmarts interior paint
1978 pontiac grand prix...
Re: interior paint
June 25, 2008, 08:58:57 pm »
SEM
⌠ŻŻŻŻŻ' [☼===☼]
Re: interior paint
June 26, 2008, 10:59:48 am »
I second SEM.
79diesel
Re: interior paint
June 26, 2008, 07:30:11 pm »
where can you get "SEM"?
scpscpscp
Re: interior paint
June 26, 2008, 07:55:17 pm »
I got mine at local auto paint store. Local upholstery shops can help you also.
lowriderbowtie
Re: interior paint
June 26, 2008, 10:58:12 pm »
I used duplicolor vinyl dye for my dash pad. worked great. and just regular automotive ext. ;paint for the metal
1976 3/4T Camper Special
350, LT headers, H pipe, Dynomax bullets, 4/3 drop
78BBSTEPSIDE
Re: interior paint
June 26, 2008, 11:02:02 pm »
I've used SEM products for years with great success.
DnStClr
Re: interior paint
June 27, 2008, 01:12:36 am »
Eastwood carries SEM products.
http://www.eastwoodco.com/index.jsp?cm_mmc=PMD_SE-_-Google-_-Brand_General-_-eastwood_
Don
87 Chevy Silverado
HAULIN IT
Re: interior paint
June 27, 2008, 10:41:17 am »
Diesel, One important step in painting plastics is the use of some type of adhesion promoter. There are many companies, I've had good results from Bulldog & PPG's DPX 801. The SEM works well, as does PPG's DIU system. On a side note, I never cared much for the body color metal (depending on the color combo) inside the cab. I've done several trucks where I painted the inside metal the same color as the plastic trim & then put flattened clear on it. I break the color on the doors at the bodyline around where the door seal is, so from the inside with the doors closed there is no outside body color showing. Just a thought, Lorne
Re: interior paint
June 27, 2008, 11:50:47 am »
If you are wanting to paint your interiror, I recommend reading this:
http://www.73-87.com/7387garage/interior/vinyl_dye.htm
biodiesel84
Re: interior paint
June 28, 2008, 06:22:23 am »
SEM products is what is standard in the upholstery industry...if you do use the SEMs products, I recommend using one of the preps that they have...they have a vinyl prep and a plastic prep...they also have an adhesion promoter also that really isn't necessary if you scotchbrite and use the vinyl or plastic prep...
Chuck.
Bitzer!
Smiles per gallon
Re: interior paint
June 29, 2008, 03:58:43 pm »
On the subject of dye- has anyone dyed the actual seatbelt? I'm changing my interior from a nasty beige to black & grey. Dont fancy having new belts shipped over!
1979 GMC CrewCab C20 1t
Re: interior paint
June 29, 2008, 04:17:57 pm »
I have. I bleached them in a bucket then soaked them in black dye. then I washed them 80 times and they came out pretty good. I painted the trim pieces black and they're still holding up.
⌠ŻŻŻŻŻ' [☼===☼]
Bitzer!
Smiles per gallon
Re: interior paint
June 29, 2008, 04:40:29 pm »
R u serious!! 80 times lol If you take the webbing out the auto roll up thing how do you tension them back up?
interior paint
