Author Topic: Flexplate  (Read 12436 times)
Offline Magnimike1
Flexplate
« on: July 01, 2008, 01:56:07 pm »
What size are the flexplates that came on our trucks?  SBC 350
Re: Flexplate
« Reply #1 on: July 01, 2008, 02:08:30 pm »
Flexplate as in automatic: 153 tooth and 168 tooth.
Or are you talking about flywheel = manual?
Offline Magnimike1
Re: Flexplate
« Reply #2 on: July 02, 2008, 12:44:39 am »
Yes I meant flexplate as in automatic.  I know some don't know the difference... I knew there were two as in 153 and 168, but what came stock?  Did it vary? Turbo 350 trans, stock replacement starter..
Re: Flexplate
« Reply #3 on: July 02, 2008, 06:30:34 am »
It depends on the engine's displacement, the trans it's bolting up too and whether or not it's internally balanced.
Offline Magnimike1
Re: Flexplate
« Reply #4 on: July 08, 2008, 10:12:48 am »
It is a 350.
Re: Flexplate
« Reply #5 on: July 08, 2008, 10:17:03 am »
Are you needing this info to replace a broken one or?
Offline biodiesel84
Re: Flexplate
« Reply #6 on: July 08, 2008, 11:13:24 am »
I also need to do this to mine, it's missing some teeth...but I have a 6.2 diesel and a 700r4...anyone know which one mine came with...thanks
Chuck.
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
Re: Flexplate
« Reply #7 on: July 08, 2008, 11:44:41 am »
biodiesel, its 139 teeth and cheap enough to replace at under $50 bucks but buying the part is the easy part  :o
Re: Flexplate
« Reply #8 on: July 08, 2008, 11:50:12 am »
I bought a 153 tooth flex plate for my 81 Blazer with a 350 for under $25 at Autozone.
Offline Magnimike1
Re: Flexplate
« Reply #9 on: July 08, 2008, 02:26:21 pm »
Thanks,
Also, what direction do I need to go with a balancer?  6 3/4 or 8". FOR a 350 not 400
Offline Magnimike1
Re: Flexplate
« Reply #10 on: July 08, 2008, 02:27:52 pm »
Bought the truck as a roller.  Piecing together everything I need to install my longblock.  Brackets, pullies, balancer, flexplate etc.
Offline biodiesel84
Re: Flexplate
« Reply #11 on: July 08, 2008, 07:12:40 pm »
hard?  isn't it as easy as sliding the tranny back and then unbolting it and then unbolting the tq converter...or am I missing something...never changed one before...
Chuck
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: Flexplate
« Reply #12 on: July 08, 2008, 08:20:45 pm »
lining up a 300 lb tranny is loads of fun---and those pesky little bolts, you know, the two at the top of the tranny that the firewall likes to get in the way of. fun.  ;D
Offline ccz145a
Re: Flexplate
« Reply #13 on: July 09, 2008, 07:52:08 am »
Quote
With the bottom bolts started, you can let the engine/trans down (don't crack the dist cap) and use a long extension and swivle to run in the bolts, then raise it back up and torque them down.
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
Re: Flexplate
« Reply #14 on: July 09, 2008, 01:25:56 pm »
good point.  if not, it is the good ole box wrench while you sit on the engine. slowly, 1/8th of a turn at a time.
