Author Topic: What do I need?  (Read 14961 times)
Offline Unofficial
What do I need?
« on: July 13, 2008, 11:05:33 pm »
I've had a 350 in the shop for a while getting rebuilt, everything is done. I got it bored out, the heads are rebuild, the crank is ground, and the whole bottom end is put together. Now I need to order parts. I already ordered the cam, gaskets, and an oil pump, but will I need anything else for the swap?
I currently have a 305 TBI with a 700R4 transmission, and I'll be swapping over to the bored out 350 TBI. I'm keeping the 700R4. I know that something has to be done to the computer. Is it a chip, or do I need to take in somewhere? I'm new to this...
1987 Custom Deluxe R10
350 TBI bored .040 over
MSD ignition
Re: What do I need?
« Reply #1 on: July 14, 2008, 04:46:58 am »
Get an oil pump driveshaft with a steel sleeve. Run a standard volume oil pump unless you plan on putting on a high capacity pan. Timing chain set? How are your tins? Intake manifold?
Offline Unofficial
Re: What do I need?
« Reply #2 on: July 14, 2008, 08:54:51 am »
Can I get an oil pump driveshaft that is made for a high volume pump and use it on a standard volume oil pump? Because I'm only seeing steel-sleeved driveshafts for the high volume pumps.
My timing chain set is good, but I forgot to ask, Will my stock 305 intake manifold fit onto the 350? Because the manifold that came with the 350 is for a carburetor.
MSD ignition
Re: What do I need?
« Reply #3 on: July 14, 2008, 10:12:37 am »
Re: What do I need?
« Reply #4 on: July 14, 2008, 10:15:58 am »
steel sleeved driveshaft will work on the stock pump, it is for replacing the plastic sleeved factory piece.
305 intake will fit any SBC.  You need a chip burned based on your engine components.  What cam did you go with, compression ratio/pistons... etc?
Offline Unofficial
Re: What do I need?
« Reply #5 on: July 17, 2008, 10:54:44 am »
This is the cam I'll be ordering: http://store.summitracing.com/partdetail.asp?part=SUM-K1102 Also, if it matters, the engine is bored .040 over.
I'm sorry, but I have no knowledge on this chip stuff, so any help here will be appreciated.  :)
MSD ignition
Re: What do I need?
« Reply #6 on: July 17, 2008, 12:02:28 pm »
You just need the prom from a 350 ECM or just pick up a used ECM for $30 and be done with it. The prom has the fuel map and look up tables burned into it. The tables are different for a 350 than a 305. Or buy this http://store.summitracing.com/partdetail.asp?autofilter=1&part=MVC%2D187121&N=700+4294914956+4294908216+4294925008+4294840140+4294908008+115&autoview=sku
Offline DnStClr
Re: What do I need?
« Reply #7 on: July 18, 2008, 01:11:11 am »
For your ecm, service number 1227747 was used in GM light duty trucks between 1987 and 1991 with engines 4.3L V6, 5L V8, 5.7L V8 and 7.4L V8 with  automatic or manual transmissions.  Since you already had the 5L, the ecm should be good to reuse. But like the guys say- you need a new chip burned because of the engine mods.
www.tbichips.com
« Last Edit: July 18, 2008, 01:21:31 am by DnStClr »
Don
87 Chevy Silverado
Offline eventhorizon66
Re: What do I need?
« Reply #8 on: July 18, 2008, 07:39:36 am »
What about fuel injectors guys?  Weren't the 305 injectors rated at 55 lb/hr whereas the 350 had either 61 or 68 lb/hr?  Not sure about this Unofficial, wait for the others to chime in.
'85 C10 SWB 350 700R4 TKO600
Offline Unofficial
Re: What do I need?
« Reply #9 on: July 18, 2008, 07:45:36 am »
Alright, a couple other things here.
I know about the injectors. The 305 injectors will work, the o2 sensor will eventually adjust the fuel input. The only thing the 305 injectors won't do is perform as well at top end, which isn't a bid deal. It's not like I'll be racing or something.
Also, is having a new chip installed absolutely necessary for the 350 to run? Because I thought the only thing the computer does is sense the fuel mixture with the o2 sensor, and then it sends information on how much more or less fuel to inject through the fuel injectors. I could be wrong, but if this is the case, then I'm not going to buy a new chip.
MSD ignition
Re: What do I need?
« Reply #10 on: July 18, 2008, 07:48:18 am »
You're right that's what it does, but only within certain parameters.  A chip simply redefines those parameters based on displacement, cam, compression, increased head flow, so on, and so on.  And plus that chip Vile showed you is cheap, why not go for it?
Offline Unofficial
Re: What do I need?
« Reply #11 on: July 18, 2008, 07:55:07 am »
I know you guys probably don't care, but my dad was yelling, having a fit because I mentioned buying a chip for my truck. He started saying how I'm not building a high performance racer (which I'm not) and I don't need some chip to give me the best performance out of my engine. He also said that if I buy this chip, then I'm screwed because nobody will work on it when there's a problem because it's a modification that is "too complex" or "not factory." That's the difference between him and I. When he does something, he'll do the bare minimum to get it to work. When I do something, I get everything I need to make my "project" the best it can be, even if it means spending some extra money.
So by not installing the chip, will the motor run like crap? How about harming the motor?
MSD ignition
Re: What do I need?
« Reply #12 on: July 18, 2008, 08:01:38 am »
Probably won't run like crap, probably won't run its best; definitely won't hurt it.  Wait for someone like Vile or Capt to look over this thread and give you more input, because I'm not a TBI pro.  But I wouldn't be worried about nobody wanting to touch it after installing a chip.  If the chip is determined to be the problem it's simple enough to remove and return to stock.  And besides you'll be the one to work on it right if something goes wrong?  Right?  ;)
« Last Edit: July 18, 2008, 10:16:00 am by eventhorizon66 »
Re: What do I need?
« Reply #13 on: July 18, 2008, 08:12:54 am »
The 305 and 350 use the same ECM, BUT they don't use the same chip or injectors from the factory.  The chip has different tables that is predefined for certain parameters on both motors.
Can you run it like it is, yes.
If you want it to run the best, you at least need a chip for a 350 due to different fuel requirements of a larger displacement.
You can run 305 injectors, but I would recommend increasing the fuel pressure.  You can run the 305 chip, but you won't be getting the most out of the motor.
Offline werewolfx13
Re: What do I need?
« Reply #14 on: July 18, 2008, 11:28:03 am »
IMO, buy the chip, fix anything that goes wrong yourself, assuming any mechanic you talk to actually cares if its got a different chip in it..99.9% wont, only a stealership will care..
My first reaction was to say buy the chip and tell your dad to go stuff himself, but since you're 16 and i assume still living at home, that probably would NOT be advisable..
If you're buying it with your own money, why would he throw such a big fit about it?
Chris
'83 Chevy c10 Silverado SWB
