Members Rides
1977 Chevy Stepside re-do
12
Topic: 1977 Chevy Stepside re-do (Read 148252 times)
cubicdollars
August 03, 2008, 06:19:27 pm »
Well with the dually almost complete I am starting to plan out my Stepside rebuild. In 1996 I pulled it down to the frame installed the 4 link, rebuilt the front end, replaced the doors,fenders,and hood, and repainted the truck.
This time around I plan on sanding the truck down and replace the door that my ex wife kicked in
as well as the putty filled rear fenders.
The big changes that are planned are
Narrow the rear end to accommodate the new Convo Pro 15X12 rims with 31X16.5 tires
Build an Aluminum flush mounted tonnou cover
Re do the wood floor
Build a Tall Deck 505, (10.2 deck, 4.250 crank shaft, 6.800 H beam rods, 4.350 pistons)
with an F2 Procharger producing 15-20 lbs of boost. Merlin Rect port cast iron heads, Dart tall deck intake manifold, and a blow through carb.
My goal is around 1000 horse power and mid 10 seconds at the track.
As soon as the heat breaks I'll be in the garage and I will post updates as I make progress
Re: 1977 Chevy Stepside re-do
August 03, 2008, 07:52:50 pm »
Sounds like a good plan!
ccz145a
August 03, 2008, 08:02:32 pm »
1K horses... nice round number
comp
76-77-78
August 03, 2008, 08:06:37 pm »
and way quicker than mid 10's
SUX2BU99
August 04, 2008, 12:04:44 am »
That sounds way awesome! Convo-pros are great, I have 15x10s in the back, with 0 backspacing and no room issues. You sure you need to narrow the rear end?
cubicdollars
August 04, 2008, 11:57:42 am »
I bought used 15X12 rims so the backspacing was not exactly what I needed, the old saying pay me now or pay me later comes to mind
, i am also installing c clip elimanators at the same time
camdenoilchange
August 05, 2008, 04:08:16 am »
sounds like a good plan. got any current pics?
cubicdollars
August 05, 2008, 08:26:26 pm »
Here you go. I took hese a couple weeks ago before I removed the rear end to get cut down.
camdenoilchange
August 06, 2008, 08:34:03 am »
sweet man! keep us posted.
lowbucktruck
Old Reliable
August 06, 2008, 02:41:00 pm »
Are you planning to tub it too? (the bed)
cubicdollars
August 06, 2008, 08:15:39 pm »
I have 67 chevy fleetside wheel tubs installed in the bed already I put those together a few years ago.
Here is the link to the truck I have had it since August of 1990 I bought it when I was a senior in High School
http://community.webshots.com/user/Thorenson?vhost=community
cubicdollars
77 Stepside overhaul , Five hundred and Five Cubic inches of Fat Momma Chevy
January 09, 2009, 11:49:40 pm »
Hey everyone
Just got my engine back from the machine shop
It's a Tall deck (SRP Flat Tops ) , Stroke = 4.250 (Callies Dragonslayor), Compstar 6.800 H Beam rods with ARP rod bolts, ARP Main Studs, 320 cc Rect Port Merlin heads ( Grumpy Jenkins series)
Final Displacement is Five Hundred and Five Cubic inches of Fat Momma Chevy. Enjoy
choptop
Extended cab fanatic
Re: 77 Stepside overhaul , Five hundred and Five Cubic inches of Fat Momma Chevy
Reply #12 on:
January 10, 2009, 06:05:18 am »
sweeeeeet!!!
Reply #13 on:
January 10, 2009, 06:16:12 am »
SICK
oldwhity
Reply #14 on:
January 10, 2009, 11:22:28 am »
That'll put the rumbly in the tumbly
Rob G.
81 Chevy K20 4x4 LWB stepside
12
Members Rides
