Members Rides
1977 Chevy Stepside re-do
10
11
12
Topic: 1977 Chevy Stepside re-do (Read 148253 times)
cubicdollars
Re: 1977 Chevy Stepside re-do
Reply #150 on:
April 14, 2014, 09:14:49 am »
Hey guys I finally got the truck to the Dyno and to the track.
After some Timing issues and a set of Bad wastegates I made about 600 to the Wheels in full street trim. My turbo exhaust housing is too small and at 5500 it starts restricting. I run a set of T72's with an .84 A/R i am hoping to replace the exhaust housing if they are availble if not I'll look at replacing turbo's next winter.
First shakedown pass I ran a 12.79 @ 106 with a 2.06 60ft, and second pass I went 11.86 @ 116 with a 2.08 60 ft.
The truck runs straight I have to tune the suspension and on the second pass I had some rocker nuts back off so I ordered a set of valve train studd girdles and I'll get it all put back together and hit the track again in a few weeks.
I believe with this set up i'll be in the mid 11's, once i swap turbo's hopefully 10's
here is my you tube channel with my vids
https://www.youtube.com/channel/UCBnzu--EqWMGI54Lx5HjDqw
bake74
Reply #151 on:
April 14, 2014, 06:16:55 pm »
Very nice video, hopefully you can improve on that.
74 k10, 77k10 Tom
square81
Reply #152 on:
April 14, 2014, 07:40:20 pm »
Awsome build. I really like seeing these truck race. You can really hear the turbos sing. Love it!!
Reply #153 on:
April 15, 2014, 06:52:36 pm »
Nice run
cubicdollars
Reply #154 on:
August 31, 2016, 10:22:59 am »
Holy Cow, I cant believe its been that long since I logged on
Well lots of stuff has changed since. I ended up leaning out this engine and I torched a few pistons. It was a super hot day and I was continuously fighting with my fuel system. I was running a Mechanical Race Pumps which worked great on cold days but with any heat it vapor locked bad.
I wrecked my Cummins swapped square body, I sold my 1966 Nova project and I bought an 07 2500 classic duramax for my daily
The Stepside was taken back apart and I built the engine that was going to go into the Nova. Its a 505 Tall Deck BBC, 4.250 Crank, 6.800 Rods, Diamond Pistons, Merlin Heads, Dart Intake, MSD Ignition, Comp Cams full roller valve train, Air to water intercooler, Water/Meth injection, CSU Blow through Carb, Custom build 2 1/4 primary to 4" slip tube headers and an F2 Cog Procharger.
I also hand build a aluminum Bed Cover added a 8 point cage and in the process of painting it now. Hoping to get it all put back together before the snow flies.
The engine is installed and runs great. I will get the bed back from paint and swap it out with the cab. when the cab gets back I'll get everything assembled and on to the dyno.
cubicdollars
Reply #155 on:
August 31, 2016, 10:28:58 am »
cubicdollars
Reply #156 on:
August 31, 2016, 10:32:10 am »
cubicdollars
Reply #157 on:
August 31, 2016, 12:27:10 pm »
SmokeShow
Reply #158 on:
September 06, 2016, 04:56:04 pm »
So nice!!
Project: 1983 GMC K30 Crew Cab Short Bed, D60 front w/ LocRite Locker, 14BFF w/ Lincoln Locker, 4.56 Gears, NP205 Transfer Case mated to Muncie SM465. Have 06 Duramax/Allison waiting to be installed
Driver: 2002 Chevrolet 2500HD EC SB D/A
LTZ C20
Reply #159 on:
September 07, 2016, 03:44:56 pm »
Looks great. And fast.
Very very fast.
LTZ Cheyenne C20
cubicdollars
Reply #160 on:
September 09, 2016, 06:10:46 pm »
Finally going to paint next Friday !!!
Captain Swampy
Wisconsin
Reply #161 on:
September 10, 2016, 06:29:55 pm »
Can't wait to see it painted. Looks great in primer.
1987 350TBI 700R4 4X4 4.56 gears 33" BFG All Terrain
SUX2BU99
Reply #162 on:
October 05, 2016, 12:26:40 am »
Beautiful underhood tube work.
cubicdollars
Reply #163 on:
December 03, 2016, 07:56:55 pm »
While I have been waiting on the truck to get back from paint, I sold my carb and bought an fitech 1200 , I got it all plumbed up now I just need the truck back
cubicdollars
Reply #164 on:
February 12, 2017, 07:41:48 pm »
10
11
12
Members Rides
