Author Topic: another a/c question  (Read 9386 times)
Offline maximus5541
« on: August 08, 2008, 03:06:56 pm »
the a/c in my 83 works. it blows cold, but the problem is it just doesnt blow very hard .  i was wondering if there was somethingthat i could clean or replace to fix this problem. i had a friend suggest that i clean the evaporator, but i thought i would ask here before i try anything. also as a side question, when i do trun on the a/c it drags the rpms down very  very low????
1983 Chevy C10 SWB, 2wd, 350/350
1987 Chevy R20 LWB, 2wd, 305/400
1983 Chevy C10 LWB, 2wd, 305/700r4
Offline maximus5541
Re: another a/c question
« Reply #1 on: August 09, 2008, 12:41:08 pm »
TTT   Does any one have a thought before i start.
« Reply #2 on: August 09, 2008, 04:18:25 pm »
If the fan motor is running at proper speeds and there are no obstructions, kinked vents or disconnected vents then clean the evaporator.
Offline maximus5541
« Reply #3 on: August 10, 2008, 08:19:08 am »
thats where i am going to start. i will check the vents and then go to clean the evaporator. Thaks for the help
Offline biodiesel84
« Reply #4 on: August 10, 2008, 11:17:10 am »
also, there is a high idle control for the a/c that will kick up the rpms when you turn it on...you may need to replace that or make sure it's hooked up right...
Chuck.
Offline maximus5541
« Reply #5 on: August 10, 2008, 04:01:41 pm »
thats what i was thinkin but when i do turn on the a/c  the rpms dont go they go down. where would i begin the seach for this high idle switch.
Offline wrangler
  • 85 C-10 350 carb 2wd recently added air
« Reply #6 on: August 10, 2008, 05:32:20 pm »
it should be on the side of your carb.
