Author Topic: removing trim on a van  (Read 4766 times)
Offline 75 C20
« on: February 26, 2007, 09:12:00 pm »
wut/how do u guys think the best way to remove trim like the chevy van below has. i want to reuse the trim after the van has been worked on -so i want to keep it nice
throw ur ideas at me
1975 Custom Deluxe 20 350 SM465 2WD Longbed
1979 Custom Deluxe 20 400 SM465 2WD Longbed
1968 Custom Sport Truck 20 327 TH400 2WD Longbed
1985 Silverado 10 305 700R4 2WD Longbed
1969 Pontiac GTO 400 Turbo350
2008 GMC 2500HD 6.0 6spd 4X4 Longbed
Re: removing trim on a van
« Reply #1 on: February 26, 2007, 08:43:00 pm »
Sledge hammer and ice pick? :evil
Use a heat gun and a plastic bondo applicator
« Reply #2 on: February 26, 2007, 08:46:00 pm »
There is a tool that works in and air hammer, but a nice wide putty knife works well. I like hyde brand putty knifes because because the handles take the hammer hits well. I get the knife started then swat it along behind the molding with my body hammer. As long as you don't bend or distort it it will be fine for reuse. I shave off the glue / tape with a razorblade on the vehicle and the trim.
Offline 75 C20
« Reply #3 on: February 26, 2007, 08:52:00 pm »
yeah i was probly gonna go this route but never can tell if there is a better way to do smth
thanks for the advice
Offline shaved80
« Reply #4 on: February 27, 2007, 02:32:00 pm »
use fishing wire/piano or guitar string and wrap both ends around the handle of a hammer (or something similar) so it looks like |----| and use that in a saw motion behind the trim
Offline DnStClr
« Reply #5 on: February 28, 2007, 05:56:00 pm »
And even before you use the fishing line, you still need to heat the molding. Once the molding is off you can use some Goo Gone and clean the surface. Then wax.
Don St.Clair
Culleoka Tn
Don
87 Chevy Silverado
