Author Topic: Which series 10 bolt?????  (Read 3972 times)
Offline 82Shortbed
« on: August 10, 2008, 09:09:32 pm »
I've been looking at slapping a posi unit in my truck, and probably even bumping up to a 3.73 or 3.90 gear.  Which series carrier?  I've seen like 2, 3, and 4 series!  Gahh!  ANd How many splines?  It's a factory '82 8.5 10 bolt.
'82 Custom Deluxe
350, 882s, stock cam...For Now
Offline 81Cheyenne
Re: Which series 10 bolt?????
« Reply #1 on: August 11, 2008, 08:39:39 am »
I believe that you're loking for a 3 series with 28 splines. I have an 81 10 blt and that's what it calls for.
« Reply #2 on: August 11, 2008, 10:17:54 am »
It should be a 28 spline.
Offline HAULIN IT
« Reply #3 on: August 11, 2008, 01:32:00 pm »
The 8.5 has a pretty large carrier run. I believe it's 2.73 up to 3.73 is the same...3 series. Some companies make the "thick" ring gear in some ratios to use with the lower number carrier also. Lorne
Offline 82Shortbed
« Reply #4 on: August 12, 2008, 01:21:50 am »
Just what I needed, looks like a series 3 goes from 2.73-4.56.  So I'll be doing that here soon too!
'82 Custom Deluxe
