How do i lean back the fuel?
Topic: How do i lean back the fuel? (Read 11234 times)
Skunksmash
Re: How do i lean back the fuel?
Reply #15 on:
August 14, 2008, 04:54:58 pm »
Thanks for the link, but i knew about EFIE's already i was just looking for an easier way. An no, i do not believe a carb will do better. I was simply saying that for leaning out the fuel, a carb is easier to do it on than some type of EFI setup.
Reply #16 on:
August 15, 2008, 10:22:00 am »
You really want to lean it out? Lower your fuel pressure. Falsify your coolant temp voltage. Just don't blame me if you ruin your engine k?
Skunksmash
Reply #17 on:
August 15, 2008, 04:46:27 pm »
I have been around this HHO stuff for about a year now and i feel like i have gotten a pretty good feel for it. Though from this thread it seems like EFIE is still the only way to go. You really cant ruin the engine with that. I was just hoping for a little screw somewhere like on a carbed vehicle. Be easier that way.
Last Edit: August 15, 2008, 04:48:21 pm by Skunksmash
Reply #18 on:
August 15, 2008, 05:25:02 pm »
There is no little screw on a carburetor that will lean it out. That's just for idle mixture.
eventhorizon66
Reply #19 on:
August 15, 2008, 06:36:01 pm »
Although there is no screw to lean out the mixture above idle, changing out metering rods and jets on an Edelbrock/Carter carb is about as easy as it gets.
'85 C10 SWB 350
700R4
TKO600
