Body, Glass & Paint
Bedliner
Topic: Bedliner (Read 9150 times)
JJSZABO
Bedliner
September 19, 2008, 04:50:08 pm »
Just finished my bedliner. I used this off ebay - two part mixture with added rubber. Worked VERY well!! I would definately recommend. Very messy job though.
http://cgi.ebay.com/ebaymotors/SPRAY-IN-on-BEDLINER-KIT-BED-LINER-GUN-PURE-WHITE_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1205Q7c39Q3a1Q7c66Q3a2Q7c65Q3a12Q7c240Q3a1318QQ_trksidZp3286Q2ec0Q2em14QQhashZitem180290526974QQitemZ180290526974
Here is my bed:
What do you think?
Jeff
86 Chevy C-10
350, TH400
Re: Bedliner
September 19, 2008, 05:01:08 pm »
Looks awesome!
ccz145a
Re: Bedliner
September 19, 2008, 05:16:20 pm »
A most excellent job!
frogman68
Re: Bedliner
September 19, 2008, 06:40:36 pm »
Cant see it to well want to come up north and do mine so I can see it better ??
Looks a lot better than what I did
I used Herculiner on the frame..
Re: Bedliner
September 19, 2008, 07:48:35 pm »
That looks Good!
bmaier
Re: Bedliner
September 19, 2008, 10:03:57 pm »
looks great! thats what i want to do to my mine.
hotrod24
Re: Bedliner
September 19, 2008, 10:46:58 pm »
i have been waiting for this great job JJSZABO lol
1978 pontiac grand prix...
JRConnieK10
Re: Bedliner
September 19, 2008, 11:14:09 pm »
Looks great. I've been wanting to try that myself.
'85 K10 LWB 350/SM465
BUILT NOT BOUGHT
JJSZABO
Re: Bedliner
September 20, 2008, 06:29:27 pm »
Thanks guys - the bed goes on the truck tomorrow.
Jeff
86 Chevy C-10
350, TH400
mp76k10
Re: Bedliner
September 21, 2008, 05:45:51 pm »
looks better than the $350 line x I had done.....
truck? what truck?
JJSZABO
Re: Bedliner
September 22, 2008, 08:33:02 am »
Quote from: mp76k10 on September 21, 2008, 05:45:51 pm
WOW - thank you
The bedliner kit came in four parts.
2 Gallons Bedliner
2 Quarts activator
2 Quarts reducer
2 Half gallon size ziplock baggies with ground rubber
a "shutz" type spraying gun.
You are suppose to mix 1 gallon bedliner with 1 quart activator, 1 quart reducer and 1 bag of rubber (the rubber is optional). But being my first time, I mixed half that amount at the beginning. I wanted to see how the gun sprayed it. Once mixed you have about 20 minutes to spray before it becomes to thick to spray. You use the empty quart sized reducer can on the Shutz gun.
Once mixed, it sprays awesome. Spray just enough to cover the paint - do not worry about thickness on the first coat. Cover the entire bed and the tailgate with one coat. Half the mix covered about 3/4 of the bed with a light covering coat. So I mixed the second half. Finished with the first coat then sprayed the tape lines along the edge to build the edge thickness(like lineX does). I put a light second coat on the sides and used up the rest of the second batch. I went ahead and mixed the whole gallon on the third batch. Sprayed a heavy coat on the bed floor and tailgate. Still had about 1/2 gallon left - but I was done. Boy was I a mess. To ease cleanup, I cleaned the spraygun with Laquor (sp) thinner and just threw away all my mixing buckets and empty cans. I then untaped everything (don't leave the tape - remove after cleanup). Used laquor thinner to clean any product off the paint (very little was there) and was done. I backed it into the garage/shop to initially set 4-5 hours, then moved it out into the sun to help dry. That's it.
Let me know if you have any questions.
Last Edit: September 22, 2008, 08:46:34 am by JJSZABO
Jeff
86 Chevy C-10
350, TH400
edcole
Re: Bedliner
September 22, 2008, 09:08:55 am »
That looks awesome!! What grit sandpaper did you use to prep for it?
JJSZABO
Re: Bedliner
September 22, 2008, 09:24:21 am »
80 and 180
I had an 80 grit cup sander that I used on my grinder and finished with 180 in areas that I couldn't get with the 80. The kit calls for 180. Thanks for asking.
Jeff
86 Chevy C-10
350, TH400
vince311
Re: Bedliner
September 23, 2008, 06:40:38 pm »
The liner on this thread looks great. I had done a couple Line-X liners in the past...which I was happy with. Recently though, I got a quote to do my 82 SWB...and they wanted $500! oy. I recently purchased the Herculiner...and will post pics when done.
'82 Chevy shortwide, 2wd, 350/350 - Sold
Body, Glass & Paint
Bedliner
