Interior & Equipment
Shift Indicator
Topic: Shift Indicator (Read 7395 times)
Thermal Izod
Shift Indicator
September 21, 2008, 06:26:19 pm »
Anyone know where/how I can find parts fot a broken automatic trans indicator? the one on top of the steering column...Mine just stays in park, regardless of gear...
It's an 82 K10 with the TH350
1982 Shortbed K10 Silverado. 305 ci with a mild cam, full true dual exhaust (Long tube headers, "H" pipe, and Thrush Turbo mufflers. 4x4, and otherwise completely stock. about 153,000 miles.
ccz145a
Re: Shift Indicator
September 21, 2008, 10:55:24 pm »
Any of the online truck catalogs have the little cable that tends to break, maybe even your local parts house's "Help!" section.
Capt, do you carry them?
Re: Shift Indicator
September 22, 2008, 02:19:48 pm »
I don't carry those at this time....
Re: Shift Indicator
September 22, 2008, 02:21:01 pm »
Fishing line works if the cable snapped and if the ear that it rides in is snapped I just usually run the cable around a screw threaded into the cluster.
⌠ŻŻŻŻŻ' [☼===☼]
DnStClr
Re: Shift Indicator
September 29, 2008, 12:32:20 pm »
I have a couple of the cables,springs, and metal panels for 3 speeds if someone needs one. I don't have any extra overdrive ones tho. Send me a pm with your address. No charge.
The orange plastic indicators can be found on eBay from time to time. I don't have any of those either.
Don
87 Chevy Silverado
vince311
Re: Shift Indicator
October 02, 2008, 09:08:37 pm »
I found a couple good ones (that I replaced mine with) at a local yard. At one point, we had about 15 c/k series trucks to pick and pull.
these indicators are spendy through the mags. Almost free at the yard. :-)
'82 Chevy shortwide, 2wd, 350/350 - Sold
Shift Indicator
