Author Topic: '86 Silverado Multifunction Switch Replacement Information  (Read 10075 times)
Offline rockable
  • Truckin', like the do-dah man.
« on: September 28, 2008, 05:42:53 pm »
I have an '86 Silverado and I decided to replace the multifunction switch.  This truck has a tilt column.  I thought it would be simple.
I'm pulled the steering wheel, lockplate, etc. but I don't see how to get the darn switch mechanism out without screwing something up.   The new multifunction switch is actually the lever used for turn signal, etc.  There's likely a C clip holding it in.  It appears that if you could take the cover off the back side of the multifunction switch that you could get to everything needed but I can't figure out how to do it without messing it up.
I have a Haynes manual but it is of little help.  Thanks for any advice you can lend or any website material you can link me up with.
Rockable
'86 SWB Silverado
Re: '86 Silverado Multifunction Switch Replacement Information
« Reply #1 on: September 28, 2008, 07:14:46 pm »
Are you trying to replace the turn signal switch or the wiper stalk?
Offline rockable
« Reply #2 on: September 28, 2008, 07:31:05 pm »
The wiper stalk.  The lever that sticks out of the steering column that has the cruise control button, delay wipers, mist, etc. on it.
'86 SWB Silverado
« Reply #3 on: September 29, 2008, 06:37:48 am »
Put it in the off position and pull it straight out. Fish the wire for the cruise up and out of the column with a piece of mechanic's wire. Pull the new one back through and stick it in.
Offline rockable
« Reply #4 on: September 29, 2008, 04:54:55 pm »
You mean that there are no c-clips or anything holding that sucker in?  Darn.  Thanks, man.
'86 SWB Silverado
Offline rockable
« Reply #5 on: October 02, 2008, 07:05:33 pm »
Thanks for the tip on the wiper stalk R&R.  That is correct.  Any suggestions on snaking the cable.  Darn, it's not easy.  I got it through the column once but snaked it through the opposite side and the cable wasn't long enough.  So, I had to pull it out and start over.
Is there a way to remove the plastic cover that's behind the wiper stalk?
'86 SWB Silverado
Offline 86 chevy silverado
« Reply #6 on: October 02, 2008, 08:37:31 pm »
Not without removing the locking clip which is spring loaded. There is a special tool that pushes the plate down to allow removal of the clip. It is possible to do without but is better done with the tool.
« Reply #7 on: October 02, 2008, 08:41:03 pm »
Actually I think your past that point at the combo switch, disregard my reply.
Offline rockable
« Reply #8 on: October 04, 2008, 04:59:50 pm »
Here is a most excellent thread on disassembling, rebuilting the tilt column and installing all related components.
http://elcaminocentral.com/article95.html
'86 SWB Silverado
« Reply #9 on: October 04, 2008, 05:04:43 pm »
That is linked in our tech pages along with a couple more:
http://forum.73-87chevytrucks.com/smforum/index.php?topic=1947.0
Offline rockable
« Reply #10 on: October 05, 2008, 05:12:04 pm »
As it should be.  That is an excellent thread.
Thanks for your help.
'86 SWB Silverado
