Author Topic: front brake squeal  (Read 5355 times)
Offline cleanall
front brake squeal
« on: September 29, 2008, 01:59:54 pm »
1987 gm high sierra 4 wheel drive truck, new front pads,new rotors, when i apply the brakes i get this high pitched squeal. anybody know how i can stop this irratating noise.
Re: front brake squeal
« Reply #1 on: September 29, 2008, 02:01:38 pm »
how new are the components?
Offline cleanall
« Reply #2 on: September 29, 2008, 02:56:18 pm »
rotors and pads are about 3 months old.
« Reply #3 on: September 29, 2008, 04:15:18 pm »
Did they just start squealing or have they been squealing since you changed them?
Offline cleanall
« Reply #4 on: September 29, 2008, 09:30:49 pm »
started squealing about 2 months after i installed the rotors and pads. by the way the pads are the very best i could get, and i was told by the salesman they would not squeal. one other change i made about  a year ago,was i installed new leaf springs on the front i went from 2 leafs in the springs to 3 leaf in the springs. this raised the front of the truck about 1 inch or less. would this effect the combination vavle for the brakes?
« Reply #5 on: September 30, 2008, 12:41:18 pm »
The combination valve would really only effect the rear.
Brakes squeal due to pad vibration. Remove the caliper, clean and lube the slides so that they move freely. Put a little bit of moly grease on the back of the pads where they contact the caliper and piston.
Offline cleanall
« Reply #6 on: September 30, 2008, 06:44:09 pm »
that did the trick. thank you very much for the tip.
