Author Topic: removing front axle housing  (Read 6549 times)
Offline junktruck
« on: October 07, 2008, 07:24:40 pm »
I am having a new ring and pinion put in the front axle housing on my truck and the guy that is doing the work i need to take the housing out of the truck and bring it to the shop.Thats not a problem but my question is how much does this front axle housing wiegh and are there any tricks to get this thing loaded and unloaded at the shop without killing myself?
        thanks ahead of time
Re: removing front axle housing
« Reply #1 on: October 07, 2008, 08:17:21 pm »
Why can't they install it in the truck? Two guys can handle moving it around. You're looking at about 200-250 pounds I would guess
« Reply #2 on: October 07, 2008, 08:46:30 pm »
Yeah I would find someone else that can do it in the truck. I have never heard of anyone not doing them in the truck, except for a reman company! That don't make no sense taking it out. Allot of extra work, plus the cost of new u bolts ::) ::)
« Reply #3 on: October 08, 2008, 04:17:10 pm »
Around here, they charge less if it is NOT in the truck. I guess because an axle takes up less space and you have a immovable vehicle sitting there.
Offline cracker0169
    • Myspace
« Reply #4 on: October 08, 2008, 05:57:17 pm »
Yank the axle shafts out and the truck is 100% moveable. Just a 2wd with a solid axle up front!
1981 K10, 350 - SM465 - NP205 sittin' on 37's
1983 C10, 305HO - TH400
« Reply #5 on: October 08, 2008, 06:01:22 pm »
I don't think any shop will pull it down and reinstall everything just to move it around during the time they are setting up the ring gears..
Offline cracker0169
    • Myspace
« Reply #6 on: October 08, 2008, 06:24:16 pm »
I would rather put the gears with the housing still in the truck!
« Reply #7 on: October 08, 2008, 06:49:36 pm »
It shouldn't take a decent guy more than 4-5 hours to set the whole thing up in the truck.
« Reply #8 on: October 08, 2008, 10:35:25 pm »
I know a guy that does it in about 2 hours.
 Why would you spend 2 or 3 hours taking it out, then however long it takes to load and drive it to the shop. Then wait a few days, go pick it up along with new u bolts, then spend  2 to 5 hours reinstalling it?
Offline cracker0169
    • Myspace
« Reply #9 on: October 09, 2008, 04:19:04 pm »
+1 ???
