Author Topic: K&N Air filter Runs To lean  (Read 7341 times)
Offline Redneckchevy
    • Photo Bucket
« on: October 11, 2008, 09:10:22 am »
Ok...Im coming here for help cause your all great help when it comes to this stuff...I have my 1097 ford explorer i installed a K&N air filter and then a cpl months later when the temp has dropped im running to lean....Anything i can do to balance it out??  And make the check engine light stay off....
Re: K&N Air filter Runs To lean
« Reply #1 on: October 11, 2008, 09:13:47 am »
I didn't know they made explorer's back then.  :P
Did you over oil the filter?
What makes you think it's lean?
Offline gbskunk2006
« Reply #2 on: October 11, 2008, 10:29:16 am »
K&N has very good customer support.  I had a question regarding the correct size of filter required for my truck and got an answer back the next day.
In this case, the link to this FAQ might resolve the problem.
http://www.knfilters.com/faq.htm#28
Good luck.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=6879.0
86 GMC C15, 4.3 Litre V6, TH400
90 Toyota SR5 4X4 Ext Cab V6 5 speed
99 Toyota Solara SLE
    • Photo Bucket
« Reply #3 on: October 11, 2008, 07:32:46 pm »
1997 but runs like a 1097.....No my code reader is saying its running lean in bank 1 and 2 K&N said go back to stock.....Im just thinking if its running lean..So im kinda stuck...My Explorer lacks power with out it....So im not sure what to do...Install new injectors? Or Is there a power tuner?
« Reply #4 on: October 11, 2008, 09:11:17 pm »
I dont understand how the filter will make it run lean, the ecm should compensate for the added air flow. Check to make sure you don't have any leaks i the air duct after the MAF sensor. If more air is getting in than what the Mass airflow sensor is reading, then it will not know to richen up the fuel. A dirty airflow sensor will do the same.
    • Photo Bucket
« Reply #5 on: October 12, 2008, 07:19:46 am »
Ill check that out today....And also will it make my idle go up and down? not much to even move the tack but u can hear it if the hood is up
« Reply #6 on: October 12, 2008, 08:20:28 am »
First thing to do is make sure you didn't contaminate the MAF sensor with that K&N and make sure like choptop said NO leaks between the MAF sensor and the throttle body. If everything checks out ok look for a vacuum leak next.
    • Photo Bucket
« Reply #7 on: October 12, 2008, 02:29:51 pm »
Contaminate the MAF  How is that done? and can it be cleaned?
« Reply #8 on: October 12, 2008, 06:57:24 pm »
If you over oil your K&N it can get on the wire. Take the MAF sensor out and clean it with rubbing alcohol. Make sure it is dry before you put it back in.
« Reply #9 on: October 12, 2008, 08:40:00 pm »
I have also seen MAF sensor cleaning spray in several autoparts stores. Be careful, the sensor components themselves are very fragile
