Author Topic: pinion nut and crush sleeve  (Read 22921 times)
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« on: November 05, 2008, 02:47:26 am »
I have been told that if your pinion nut is loose you can just retorque it to 125 ft lbs and it will be fine. Just wondering why the crush sleeve wouldnt need replaced? thanks
Re: pinion nut and crush sleeve
« Reply #1 on: November 05, 2008, 01:04:08 pm »
The crush sleeve is "crushed" to tolerance. so yes you can retorque it.  If it was loose for a while though, think about the bearings.
« Reply #2 on: November 05, 2008, 02:10:04 pm »
I don't know where you got that torque spec but no that is not correct. Bearing preload is measured by rotating the pinion gear at the yoke with the differential carrier removed using an inch lb dial type torque wrench. a small beam torque wrench can also be used. 15-25 in lbs is ideal. If you have to replace a pinion seal make a witness mark on the location of the nut to the pinion shaft and the companion flange using a punch. If the nut is too loose kiss your ring and pinion goodbye. If it's too tight kiss your bearings goodbye.
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #3 on: November 05, 2008, 03:03:06 pm »
I went down to the gmc dealer and a gm tech of 30 years gave me that torque spec. I didnt think to ask him why the crush sleeve wouldnt need replaced
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #4 on: November 05, 2008, 04:34:35 pm »
I went back to the gmc dealer and asked about the torque specs and he told me approx 125lbs trq on the pinion nut was not enough to crush the sleeve anymore but it was tight enough to hold things tight and to pull the pinion up to approx the set point it had prior to coming loose in most cases.
« Reply #5 on: November 05, 2008, 06:55:17 pm »
Well he's wrong unfortunately. Once the collar is crushed it's crushed. You might want to pull it apart and see why it loosened up in the first place.
Offline DnStClr
« Reply #6 on: November 06, 2008, 10:34:21 am »
That mechanic must have been thinking about the ring gear. Here's a chart from Drivetrain.com- you can see Vile's right.
http://www.drivetrain.com/gm9.5.html
Don
87 Chevy Silverado
Offline 75stepside454
« Reply #7 on: November 06, 2008, 10:46:43 am »
Villa is right
Offline tusk
« Reply #8 on: November 07, 2008, 10:28:31 am »
thats what i was wondering,why in the heck is loose in the first place
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #9 on: November 07, 2008, 11:43:31 am »
Its more common than you may think for them to come loose. Just do a search on google. You will find alot of hits.
Offline tusk
« Reply #10 on: November 07, 2008, 11:51:35 am »
i know i haven't seen everything before,but Ive been in the automotive business since i was 14(first job was at a parts store)and have been at the dragstrip since i was born and i have never seen that happen,unless whomever put it together did a half-done job
