Author Topic: Electronic control box for E transmissions  (Read 10708 times)
Offline HAULIN IT
« on: November 06, 2008, 09:13:49 am »
Anyone have a 4L60 or 80 E in their truck? Who's controller are you using...just looking for opinions on a stand alone type.  Thanks, Lorne
Re: Electronic control box for E transmissions
« Reply #1 on: November 06, 2008, 11:51:53 am »
I have one in my 1991 CrewCab.  The ECM controls it and the TBI.  What are you looking for.  P30? Vans had a controller in them that some people have modified...
Offline HAULIN IT
« Reply #2 on: November 06, 2008, 12:34:14 pm »
Chris, My transmission buddy suggested we try an electronic, I've seen companies that make a  programable set-up to alter shift points, lock-up, ect. that you would plug in a laptop or some pre-determined "program 1" & "program 2" or something like that. Just wondering if anyone has first hand experience with a certain company & their thoughts. Lorne
« Reply #3 on: November 06, 2008, 02:35:16 pm »
They do have programmable E's, but the good one cost $2500.  The only stuff I have experience with it the 99-up LS motors that we turbocharge and tune...
There are a few that have stand alone PCM's but they are expensive also...
Offline eventhorizon66
« Reply #4 on: November 06, 2008, 04:40:09 pm »
Here's one.  HGM Compushift  Can't vouch for it, but it looks nice.
'85 C10 SWB 350 700R4 TKO600
« Reply #5 on: November 06, 2008, 04:55:19 pm »
Wow, they came down to about $1200.  That is the one I am talking about.  For the money it is the best you can get.
Offline HAULIN IT
« Reply #6 on: November 06, 2008, 05:02:14 pm »
Yes, That's exactly what I was looking at. There are several others out there too, most use your laptop though.
 Chris, On a side note, Is your brother locking up his converter during a dragstrip pass?
 Thanks Guys! Anyone else have any input? Lorne
« Reply #7 on: November 06, 2008, 05:40:37 pm »
No he is not locking the converter. he is making to much power and has gone through 5 4L60E's, so it would break it.  If/when he gets an 80 he is going to lock it.
Offline HAULIN IT
« Reply #8 on: November 06, 2008, 07:31:53 pm »
Chris, What is he breaking/burning up on the 4L60's?
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #9 on: November 06, 2008, 09:52:30 pm »
I have the 4L80E in my '91 GMC, but she's all stock.
« Reply #10 on: November 06, 2008, 10:24:53 pm »
well the first 1 broke with factory setup.
The second one burnt up after the turbo.
3rd one broke the input shaft
4th one burnt up the pump.
5th one just got installed.
Truck is making 535hp and 703lb/ft at the rear wheels.  He hopes the trans will last for Pink all out next weekend.
« Reply #11 on: November 07, 2008, 10:22:41 am »
You mean a 4L60E can't stand up to a pathetic 850+ flywheel ft/lbs.  Jeez they are weak.  :P
Offline tusk
« Reply #12 on: November 07, 2008, 10:23:03 am »
i thought gm and painless was making stand alone controllers fro these trannys
« Reply #13 on: November 07, 2008, 03:01:48 pm »
Yeah I know.  That is what I was saying.
I convinced him to dump Finishline, the input shaft that broke was because they didn't put a hardened on it.  He raised cane, but they still charged him (in my opinion) way to much to fix it, of course this was after they recived it..  My opinion was they should have ate all the expense on that one...
We found a supplier for 80 parts locally so hopefully he will go that route.
