Author Topic: anyone run this cam before?  (Read 3852 times)
Offline 84shortbed
« on: November 14, 2008, 11:09:14 pm »
It`s a Crane SBC cam. Here is the link to the specs
http://cranecams.com/?show=browseParts&action=partSpec&partNumber=113932&lvl=2&prt=5
My 355 is 9.2:1 compression and I have Speed Pro flat top hypers. The heads are 882 heads that already had 2.02/1.6 valves in them when I got them. It`s going in my 84 step side.
Anthony
83 chevy short fleetside
OTR gearjammer
Re: anyone run this cam before?
« Reply #1 on: November 15, 2008, 06:49:01 am »
What is your goal? What intake do you have on it? Carb? Headers? what transmission and final drive gears do you have? I would go more aggressive personally.
Offline 84shortbed
« Reply #2 on: November 15, 2008, 09:39:49 am »
It`s for my daily driver . I`m going to use a performer intake with egr and my original q-jet. I`m planning on headers eventually but I`ll run the stock exhaust manifolds for not. The tranny is a 700R4 with a stock converter which I don`t want to change and I don`t know the rearend ratio yet. I can`t go too wild because it has to pass CA smog. I haven`t had anything I had to smog in a long time and I usually go with a bigger cam and more compression but since I have to smog this I don`t know how big I can get away with.
Anthony
OTR gearjammer
« Reply #3 on: November 17, 2008, 02:11:42 pm »
I would look at a CARB exempt cam if you have to pass emissions.
Offline 84shortbed
« Reply #4 on: November 17, 2008, 02:15:40 pm »
It is a CARB cam.
CARB EO Number: D-225-18
Anthony
OTR gearjammer
